olddude
Olddude - your situation doesn't seem as dramatic as mine; both the images you posted show the connector pointing out horizontally (BTW, these images both look like half shells, not full shells, like mine. Are your SCS half shells?). Of course, with a swivel connector, you can eventually make the wire go anywhere you want, but if you leave the memory wire in and the mmcx connector points down at a 45 degree angle, you have a big wire loop over your cheek, rather than behind your ear. Removing the memory wire helps, but I'd still rather have a lower-profile SCS with connectors pointing up at 45 degrees as Shure intended them to (and as they would with any universal-fit tip).
Anyway, good luck Kapazza - I hope the re-made shells work out ok for you. Please let us know.
I have full shells- that's what Sensaphonics makes for the 846. My picture (on the left) and the Sensaphonic picture (on the right) show where the 846 "points" and how the wires can be routed either up or down. According to the above, the angle of the wire/connector may depend on the size of your ear canals.
As to sound, like any tip the Sensaphonics depend on proper fit to work correctly. Mine do. As I have repeatedly stated, Sensaphonics has excellent customer service and the first step upon having issues with your new sleeves should be contacting them directly. Posting here may get you some suggestions, but the way to get corrections is to contact them and let them follow through for you. There are nineteen pages in this thread, and all but about three or four people have reported total satisfaction with their sleeves.
