Swimsonny
Aka: thegardener & ScooterBilly
Undeclared Member of the Trade: Inearspace
writing positive reviews of products he was reselling.
- Aug 29, 2011
Thanks man. It is engraved, well looks to be, and i would take a guess that it is layered from the look as it is different to a scratch. This will be the latest version as it was sent direct from Ortofon.
Thanks man. Yes, i would like to get my hands on some GR10 in the hope they are okay as i was overall disappointed with them sound wise, not worth near the price and the GR10 have always been quite hyped.
Thanks man, glad you liked it!
Thanks a lot! Yes it is very good isn't it. What i will say is if you can get some smaller tips then you will get a deeper insertion so less likely fall out. Also you could try the included comply tips although the sound will be altered slightly. Also for ear-hooks i have not found a need for them but Phonak and Meelectronics both sell them.
Oh that is cool. I have found them great at staying in my ears personally whether i am at home, on the train or out in town!
Actually i think that i am wearing them right as no earphones will have the writing upside down when worn. The writing is up the right way when cable down so that is likely correct. There is nothing that implies over the ear use like with any IEM that is made for over ear use. I had a perfect seal and is till have tried over the ear. These have silly little bass that is awfully rolled of. Makes the DBA_02 bass heavy hahah!
I have wrote all of the bold and just didn't agree with the warm part.
Quote:First Review
And i have agreed with quite a bit of the other review too again other than the warmth, i said the bass for example is not bad in quality vs say the SE530 but not there in impact or as this guy says slam.
I do not really care what google reviews say about them but i have heard many IEMs for the price and many a lot lower and these would be correctly priced at £100. They would be a bargain a lot cheaper. And at a google a lot of review sites rate them poorly and they are normally positive about a lot. I also never said i did not like them just that their was a lot better, check my round up thread, they are ranked like 7th in line with the GR07 which is not shabby.
Oh and i did not mean to come back argumentatively, i take everything on board constructively and appreciated what you pointed out, especially about the metal. I will say though that i think they are made to be cable down because of the writing and packaging.
Nice review. The e-Q5 you have are the one with laser engraved "ortofon" word ?
very nice review - i wish someone would do a similar presentation between eq-5 and gr-10
cheers![]()
nice review man, loving the comparisons...
very good review! owning the eq-5 for a few months and very satisfy with its performance, how ever eq5 pop out of my ear from time to time and I really need to find a pair of ear hooks or better tips.
I've been using the silicone ear guide from Sennheiser ie 8 and they stay totally intact in my ears. Also the little black wire tryst tie things that secure cables makes a nice cinch cord on the eQ-5.
LOL. How do you really feel? Just thought wearing them as designed might help since your only issue with their sound was the bass. Might not but other found them warm and the opposite of your take on their tonality. Maybe they didn't just 'sound' like they had a bad seal. http://www.headphone.com/headphones/grado-gr8-earphones.php Again, I haven't heard them but the consensus has always been that they were on the warmer side though not bassy. Those that haven't been enamored (like almost anything) have thought it too dark. Google GR8 reviews and I think you'll find that they're not poor. Even the guy you borrowed them from rated them as VG. Perhaps not your flavor or as good a value as something else to a given individual but the odd physical description and usage along with that last comment are not the sort of thing I expect from a review. You're allowed not to like them. I may not as well but wow.
I didn't think a couple of valid corrections would get you all reactionary. Sorry if I over stepped but I though the non opinion stuff in reviews should be accurate and correctoins welcomed.
I think silver is a good choice on a good phone.
Quote:First Review
I've tried six or seven different IEMs over the past few years, and the Grado GR8s are far and away the most comfortable and easy to wear out of all of them. They are tiny, and have very comfortable gel tips. Microphonics are not detectable when I wear them over the ear (I haven't tried wearing them down).
The sound signature is my favorite out of all the IEMs I've tried, as well. The imaging is very precise and the timbre is very natural. There is a really nice sense of air/space in the music that reminds me a bit of the on-ear Grados I own (although they do not have the aggressive treble and sparkle of the on-ears). There is a nice amount of detail. I especially like them for small jazz and chamber ensembles, but I haven't listened to anything on them that didn't work well. They seem like good IEMs for all-around listening.
If I had to nit-pick: they are a touch on the warm side of neutral; and the soundstage is on the small side for an IEM of this caliber.
