siwei87
- Oct 12, 2010
how does 50 and 70 compare to turbine pro gold and copper. especially bass, thanks
Yesterday I tried the JVC Spiral Dots to my ATH-IM03. The sound really good! In my opinion, the treble was smoother than Sony Hybrid eartips.
I don't understand how you could get a good seal with the IM50 but you couldn't with the IM70 as the housings are the same size?
Not really, the IM70 housing is slightly deeper than the IM50, though the shape is relatively same. this added bulk makes the IM70 difficult to sit in my ear, it feels like it will drop out.
As I said, I did tried both of them and A-B ed both for 30mins tops at the local headphone shop and at the end of the day found that I can get the IM50 fit my ear (with a bit of trial and error) than the IM70.
But then again it is my ear shape/size causing this fit issues so I think people with bigger ears or the appropriate ear shape will not encounter this issues then definitely go for either of this great value iems from ATH.
The tip mod definitely does help to achieve a good isolation and fitting.
Looks like Golden ears just did a measurement on the IM-02s!
http://en.goldenears.net/index.php?mid=GR_Earphones&document_srl=49122
I am a bit confused reading the bar graph at the bottom under reviewer's opinion though. When the IM02s were mentioned being compared to the etymotics, I had assumed the transparency/coloration to be greater than 0 but it's only at 0!
I have the UE900 and when I read the measurement for it, I thought the veil in the mids I was hearing was relevant to the transparency/coloration rating! (it was rated 0)
Anyone able to give their opinion on their clarity of im03s as I am about to order again but still trying to read a bit more before i order? Would be helpful for it to be compared to the UE900s!
Thanks
Thanks for the link! Interesting!
IM02 frequency response varied greatly with the players output impedance. I think we can assume the amp used for the measurement has very low output impedance.
IM03 sounds clear to me, no veil at all, although IM02 sounds a tad clearer. IM04 when compared to IM03, might sounds a tad veiled.
while IM03 a bit warmer but in no way it was veiled
Wow, serious phase lead/lag on the IM-02's.
Anyone who has IM-02 find it distracting?
