Beau Cauchemar
- Nov 5, 2016
Are you using the extension to mount the V5 horizontally in the case?
Yes. It's hanging off to the right side (the toroidal transformer side) floating above the mosfets but not touching anything. I should mention that this config was a rather tight fit. With the extension's socket going into the board's socket, the extension's wires are at a tight bend and touching the top vent. No room to spare really. A straight-into-board's-socket vertical install would require cutting a hole in the top case vent (or not having the cover on.) Although since this socket region seems to be a tad hotter than the surrounding areas, I wonder if it isn't better to have the V5 be hanging off the side of the opamp board.
Another interesting thing to note...the plate of capacitors was installed with the vertical heat sink towards the back, which is backwards compared to your pics (and other reviewers interior pics.) I switched it back around though so the heat sink was under the top vents instead. I even contacted Optomo to see if the change was intentional, but got a response back that "they didn't have any schematics to reference. Sorry." Huh... Well anyway, I hope I made the right move making my layout the same as your, earlier-assembled models.
