Maniac
Member of the Trade: Acoustic-Fun Co., Ltd
- Sep 2, 2003
There's a lot of bit-perfect sound devices, but due to intel's infinite wisdom when defining sound card standards, they decide to resample everything to 48KHz so that they can easily mix sounds digitally. This decision makes sense on the engineering side, where everything gets quite simple when you want to play multiple sound at the same time. You no longer need complex analog mixer and multiple DACs, but they also cut the corner in the resampling system where it is done very poorly and without any way of bypassing the resampler.
Later sound cards are somewhat poisoned by the spec where they didn't bother to add a feature to bypass the resampler when required. Thus the discussion on bit-perfect capable sound card started, and as it progresses, it appeared that more and more sound chip designer are looking into this feature and even onboard sound seem to carry this feature now.
That's basically the whole story that I can recall off my head.
Originally Posted by 8140david /img/forum/go_quote.gif I don't understand. Why do you need a bit-perfect sound card with the DA-131? Why can't you, on vista, send the signal unmodified using wasapi? If you do so, you're not using the internal sound card, are you? Is it that a sdpif output always relies on the internal sound card? |
