[Review] Grado GR10, Ortofon e-Q5, Westone 4, Final Audio Design FI-BA-SS
Apr 27, 2011 at 12:37 PM Thread Starter Post #1 of 42
rawrster
Introduction
A few months ago when I got my second custom in the 1964 Ears 1964-T I thought I was done buying new universal earphones. Looking back I see how naive I was then. I bought (on impulse) and sold the CK10. I also later bought the newly released Westone 4 on impulse again like any good head-fi member. I also had a standing loaner offer waiting for me by another head-fi member and I was allowed to choose whatever earphone in his possession that I wanted for as long as I wanted to try them out as long as I give my opinions on them. It should be fairly obvious that those earphones are the Ortofon e-Q5, Grado GR10 and Final Audio Design FI-BA-SS.
It should be obvious to many that the head-fi member who loaned me those three earphones is none other than james444. So before I move on to the actual review I want to thank him once again for these loaners. At the same time I do have to question his sanity on his earphone collection hobby.
Useful Links
I realize that not everyone here is used to the audiophile terminology and as much as I hate using those terms it makes things so much easier. I will include two links and both are very useful. One is an audiophile dictionary and the other gives you a general idea of what instruments operate at what frequencies. I will be using those two links as references for this review.
Audiophile Dictionary: http://www.integracoustics.com/MUG/MUG/bbs/stereophile_audio-glossary.html
Frequency Chart: http://www.independentrecording.net/irn/resources/freqchart/main_display.htm
Disclaimer
Consider this review as just one person's opinion. This review is not meant to be anything beyond that. We all have different preferences, references, gear, etc. so as the typical head-fi disclaimer this is all imo so ymmv.
I also realize that not everyone who reads this is aware of my preferences so I will list them here. My preferred sound signature (although I do enjoy many) is something that is fairly neutral. For example my favorite earphone based on that signature is the Audio Technica CK10. I listen to a wide range of music genres with the exception of classical.
Review Gear
Unless otherwise noted the gear used in this review is with my Audinst HUD-MX1 dac/amp connected to my netbook (Asus EeePC1005HA). The media player used is GMPC+MPD and the files are all 16/44 FLAC.
Manufacturer Specifications
Grado GR10
20-20k Hz | 32 Ω| 116dB | 1.3m
single Moving Armature
$399 at www.soundearphones.com
Ortofon e-Q5
10-20k Hz | 40 Ω | 118dB | 1.2m
single Balanced Armature
$288 at www.musicaacoustics.com
Westone 4
10-18k Hz | 31 Ω | 118dB | 1.3m
quad BA in a 3 way crossover
$449 at www.earphonesolutions.com
16 Ω | 112 dB | 1.4m
custom single BA using Balanced Air Movement (BAM)
Price No Object at www.amazon.co.jp
Sound Signature
Grado GR10
To kick things off I will begin with none other than the Grado GR10. The GR8 while being liked by some was a disappointment to a couple of head-fi members that I have asked. Having never heard the GR8 but knowing that these were a Moving Armature driver based earphone I was excited to hear the GR10 and having read a couple of reviews of them I had pretty high expectations for them and they definitely did not disappoint.
If you have ever heard the Ortofon e-Q7 then you more or less know what to expect. These while having good texture, detail and resolution are by no means suitable for a bass head (the same applies to the rest of these earphones in this review). There is a good amount of impact to them when the recording calls for it and while it is not thin it definitely is not bass heavy or suitable for those who just want lots and lots of bass. Extension while being quite good does have a slight roll off at the lowest of lows. Decay is more accurate than some earphones which are lightning quick and bass notes disappear just as fast as they appear.
The midrange of the GR10 is a bit unexpected since I expected something more similar in forwardness as when I had the Ortofon e-Q7. The midrange has much better balance with the bass and treble than I initially expected but that is not a bad thing. The quality of the midrange is very good. It offers good detail, texture, resolution and clarity so those worrying about lack of technical ability have nothing to worry about.
The midrange of the GR10 is very good. It is slightly forward in nature but overall there is a good balance between the treble and bass. There is no bass bleed in the midrange although there is a slight hint of warmth in the midrange which I do like. Detail, resolution and clarity is great. The clarity of the GR10 is definitely near the top of everything I have heard which is pretty impressive.
The upper midrange and treble like the rest of the spectrum is very good. The GR10 is an airy earphone with a good amount of sparkle but yet fairly smooth. I do not hear any noticeable peaks or areas where harshness may appear. It remains detailed with high resolution but without having that harshness that gives the user the impression of a great treble at the expense of the midrange or bass.
The sound stage of the GR10 slightly above average. Imaging and separation are just as good giving the user a good overall musical experience.
Ortofon e-Q5
Having enjoyed the e-Q7 when I owned them a while back the e-Q5 is definitely something I was looking forward to especially with the reports that it has a more extended treble.
The bass presentation of the e-Q5 is remarkably similar to the Grado GR10. If I didn't know any better and there wasn't a difference in the housing between the two I would say that I was listening to the same earphone if just listening to the bass. Texture, detail, resolution are all just as good as the GR10. The disclaimer for bass head applies here as well. In fact if you are a bass head you should not buy any of these if you are looking for something that will suit your bass cravings. Extension while being good does roll off at the lowest of lows similar to the GR10. In fact the only difference I could find after many A/B comparisons is that the e-Q5 has a bit less bass amount.
The midrange of the e-Q5 is where the two begin to differ. While it is not forward like how I remember the e-Q7 to be it still is slightly forward. The midrange of the e-Q5 is what I would like to call sweet. While I wouldn't call the e-Q5 a midrange dominating sound it still does have a slight focus. The midrange does not dominate the rest of the sound for it to be just midrange. Detail, transparency, resolution and clarity are all pretty impressive with the e-Q5. This earphone definitely has a slight emphasis on the midrange but it doesn't make it the focus where the rest of the spectrum is overshadowed by the midrnag.e
Moving up to the upper midrange and treble it is smooth with a decent amount of sparkle and air. Detail is good and at no point do I hear any harshness or any aggression like another earphone that I will mention later in this review. The extension up top is also good and there is no noticeable roll off that I can hear.
The sound stage is slightly above average with good depth and width. Separation and imaging very much like the GR10 is excellent.
Westone 4
The Westone 4 is the first released four driver BA earphone and with Westone's track record of releasing good quality products I had high expectations for this earphone.
Starting with the bass I was definitely not disappointed. The Westone 4 has the best extension of a BA universal that I have ever heard. I have not heard all of them so while it possibly may not be the best it is the best for me. Although the Westone 4 boasts two drivers alone for just the bass it by no means has excessive quantity or qualify as a bass monster. The impact however does exceed the GR10 and e-Q5 and slightly less than the FI-BA-SS. The quality of the bass however is very good. Detail, resolution, extension and texture is right up there with the best universals that I have ever heard. Decay is also quite good and offers a fairly realistic decay without hanging around too long or disappearing too quick.
The midrange in a nutshell is extremely smooth much like the rest of the spectrum with the Westone 4. While I do consider the midrange slightly forward it by no means is too forward where it becomes a distraction to the bass and treble. The midrange of the Westone 4 does have a bit more warmth than the rest of these earphones so as a result the clarity does suffer a bit. The notes also do have some thickness but by no means does this mean that there is a veil with the Westone 4. Detail, resolution, texture and the overall quality of the midrange is very good. I would actually say that out of all these earphones the midrange of the Westone reigns supreme. The midrange is slightly sweet much like the e-Q5 but with a bit more warmth.
The upper midrange and treble is also very smooth. This makes it very inoffensive and I would be surprised if many people found the top of the Westone 4 offensive like how some other earphones are. I do not hear any noticeable peaks or harshness here and it is not aggressive so that makes very pleasing for me. However do not make the mistake for a smooth treble to mean a roll off or lack of detail. In fact the Westone does not lack either. It has good extension and plenty of detail. There is no issue in terms of technical ability with the Westone 4 in the treble or any other area for that matter.
The sound stage of the Westone 4 is definitely above average and very wide. However instead of very wide left and right it actually does a good job in filling the gaps so it is not just front, left and right but it gives a very convincing sound stage for an earphone. Imaging and separation is just as impressive as the sound stage.
These earphones are very special and shocking in a couple of ways that definitely was the cream of the crop in terms of my excitement as I looked forward to listening to these the most. James444 made a special endorsement in his original review that anyone who liked the e-Q7 and CK10 would like these and those were two of my favorite universals as well as the price no object price tag of these.
Starting off the FI-BA-SS boasts a very impressive bass for a single BA driver. It is by far the best bass I've heard in a single BA driver. The bass has very good detail, texture, resolution and even a slight rumble to it. The FI-BA-SS although being BA is very unlike many BA I have heard where it is lightning quick so decay is too short to sound natural. It actually is not that fast where notes disappear just as fast as they appear but it has a much more natural amount of decay so the bass sounds much more realistic. There is a slight roll off like the GR10 and e-Q5 where it happens at the lowest of lows but few earphones are able to have good linear extension there.
The midrange while having a hint of warmth is the real surprise here and definitely something I did not expect. It has such unprecedented clarity that it makes the GR10 seem like it lacks clarity in comparison which is definitely not the case as the GR10 is up there with the best of them in clarity but next to the FI-BA-SS that no longer holds true. The midrange as a whole has the typical qualities that makes for a high quality midrange. Those being very good detail, resolution, texture and in the case of these earphones amazing clarity. However there are also some issues. These are very revealing earphones and I mean very revealing. The earphones leaves just you and your source and I really mean it. If your source is bad or your recording is less than stellar the FI-BA-SS will scream in your face telling you that it is not amused. There is this type of raw aggression that I have never experienced previously.
Similar to the midrange the upper midrange and treble also boasts the same type of resolution, detail, clarity and shows you just how transparent these are. Once again I must stress that anything less than stellar should not be paired up with these earphone for they are very revealing. There is a slight peak here so there is some harshness but nothing too extreme. The bigger issue at hand is the raw aggression and revealing nature that is the main attraction with these earphones and depending on your sources that may or may not be a good thing.
The sound stage is quite good here giving you a nice large stage. Separation and imaging is also quite good but not the best of these earphones. The overall tone of the FI-BA-SS is that these are fairly balanced with a bit of a peak up top to go along with amazing clarity and transparency as well as this raw aggression.
Conclusion
All of these earphones are all very good so technical ability should not be a concern. It really does depend on your preferences as they all have slightly different sound signatures and I can see people owning multiple of these earphones with the exception of the Ortofon e-Q5 and Grado GR10. There really is no reason to own both since they are quite similar unless you just want to own them both.
Apr 27, 2011 at 12:38 PM Post #2 of 42
rawrster
reserve if needed
also sorry for the crappy pictures but my picture taking abilities is very lacking :p
Apr 27, 2011 at 4:43 PM Post #3 of 42
Pianist
Great review! Thanks rawster.
I agree with your assessment of the e-Q5 completely and I see that GR10 is not really something that I need to try. I thought the GR8 also sounded very similar to e-Q7 BTW.
Apr 28, 2011 at 12:54 PM Post #4 of 42
rawrster
I guess we agree on an earphone for once :) The e-Q5 is a nice earphone although I can't say I'm a fan of that bullet style insertion that the e-Q5 comes with. That's part of the reason I like the GR10 so much. it has one of the smallest housings I've ever used.
Apr 28, 2011 at 7:01 PM Post #5 of 42
Anaxilus
Great stuff Rawrster.  Your findings definitely confirm some impressions I had about MA's.  The EQ5 is a very good phone.  Do you find the FAD to exceed the DBA in clarity also?  I'm really intrigued by how that thing sounds.
Apr 28, 2011 at 7:21 PM Post #6 of 42
rawrster
I'm not sure if MA earphones are because the manufacturers are gearing towards accuracy or if that is just the way they are going to sound for now until more time passes and more companies pick up MA based earphones. It may be something similar to the perception that dynamics had a few years ago but now there are plenty of dynamics that have the stereotype dynamic sound as well as the more accurate type of sound. MA is still fairly new and not as many using them.
As for the FI-BA-SS I find that they best everything I have heard in clarity. That includes the DBA-02, CK10, GR10, e-Q5, etc. I consider those four earphones to be on the same level of clarity. I do consider the FI-BA-SS to be a very good earphone (although overpriced for what it is) but the clarity is not something I have heard before. The only real issue I have with them is their aggression with lower quality tracked. With some earphones you can get away with just FLAC and a sub par recording such as the album Californication by Red Hot Chili Peppers. I have the FLAC version of that album but the recording is not the greatest. With the FI-BA-SS not only do you need a high quality file such as FLAC but you also need good mastering.
Apr 29, 2011 at 12:38 AM Post #9 of 42
takoyaki7
It is amazing that pretty much anything sounds veiled compared to the FI-BA-SS. The unfortunate tradeoff is their ruthlessness with exposing flaws in poorly recorded tracks, but I always find them a breath of fresh air when going back and forth with my other earphones. Their "rawness" is really something else, especially comsidering that they are BA, as dryness is the usual consequence of BA accuracy...but the FADs do a better job of combing dynamic and BA attributes than anything else I have heard!
Apr 29, 2011 at 8:16 PM Post #10 of 42
rawrster
That definitely is a unfortunate trade off. As great as I think the FI-BA-SS is I can't justify owning an earphone that is only suitable for certain songs. Not everything I have is well mastered so only certain types of music sounded good with them. One such was jazz as I don't have many tracks that are poorly recorded. The same cannot be said for a lot of the other genres of music I listen to. That makes the FI-BA-SS suit only someone who is looking for a very unique signature which is what they are. The aggression and transparency they have is really something else and not something I've heard before. There's a boundary to how revealing an earphone should be and the FI-BA-SS crosses that line if you don't connect it to a good source.
Apr 30, 2011 at 1:21 AM Post #11 of 42
Nachkebia
FAD`s cost $1000? :basshead:
Apr 30, 2011 at 3:25 PM Post #12 of 42
rawrster
I don't remember the price when I saw it on Amazon Japan but it should be in that vicinity. It's not cheap and definitely not the best bargain but it does sound good if you fit that particular sound signature and willing to pay. It's probably one of the few earphones where I would want to audition before trying since resale value is not very high.
Apr 30, 2011 at 4:36 PM Post #13 of 42
james444
Excellent review, rawrster! Have to agree with pretty much everything here, including the part about my own sanity :p
Regarding the FI-BA-SS, I wouldn't recommend these to anyone as their only pair of IEMs, since they're just too unforgiving for that. But for close listening with well mastered recordings they are truely a stunning experience and unlike everything else I've heard. However, their price is a real shame, because otherwise they'd surely be much more popular here.
Apr 30, 2011 at 6:24 PM Post #14 of 42
rawrster
Maybe if all my music was from HDtracks or a similar place I wouldn't mind the FI-BA-SS as my main but unfortunately it is not as I do have a good amount of tracks that do not have the best mastering.
I kind of regret sending them back already as I had a nice dac/amp come in the mail today and all indications point to it being much better than what I used for this review. It would have been nice to see how the FI-BA-SS scales up with something much nicer.
Apr 30, 2011 at 11:30 PM Post #15 of 42
Nachkebia
another question is, does GR10 worth double the price of e-Q5? :rolleyes:
