Originally Posted by wilashort /img/forum/go_quote.gif
Thank you for your answer GradoFan2, is very useful; but in what scale you put the Denon D5000 and the AD2000 in bass slam (Punch not boom). You say here that the Denon has more, but below you say that both has the same....?
I known that the bass in the Denons are more robust and has more quantity, because it is closed and is known by his emphasis in this bass (specially low to midbass (some say that it is bloated, but i don't care much (it can be very good with trance...))), but that interest to me is extension and Slam mainly.
Ah, and for you which of the two, sound more lifelike with voices and instruments (or in the mids overall)
And for last; the AD2000 have faster mids than the D5000, Do it??, how much is the difference?
I want (in general) a headphone with faster and forward mids for Jpop, Jrock, super Eurobeat styles and faster music as some space music too of some video games; because i find my DT990 a little laidback (in the mids) with many of the music that i like most.... but with movies, TV and Anime, it excell (but it is another history....)
Another thing, is what with either of them. Can i listen the phone for example or listen the bell...?.
One of the reasons for which, i could buy the Denon; is because it is closed and have low isolation (but i am a little undecided) and because i need to listen to the around sounds, that with my DT990; i can't to listen the phone, the voices of other persons and other sounds.... But even it can be a little uninvolving with the music previously named.
I want to feel the same emotion that i felt, when i had/listened to my ex 5.1 speakers (Altech Lansing VS3151) (near to full volume), but i can't use speakers anymore...
Uh... well...
The bass of the D5000s is more "boomy," than the AD2000s - though it's not sloppy. It's just richer, fuller, more liquid sounding... and... it is more dominant in the overall balance than the AD2000s. The AD2000s' bass is tight and clean, and extended - about as extended as the D5000s, but not as loud at the lowest frequencies as the D5000s. So... if you like clean, tight fast bass, with impact the AD2000s bass is superior - very much like Grados.
The mids of the AD2000s are more prominent, though not dramatically so. They're also a bit cleaner and crisper - whereas the D5000s mids are a bit richer, more liquid sounding, with a bit more "organic, texture." The D5000s are great for acoustic, jazz and classical music. They sound more like the Senns, than the Grados, though the wood Grados have the same "organic, texture in the mids.
The highs are about the same - though the AD2000s, again, are a bit sharper, crisper, cleaner, and a bit less "organic, and textured." The AD2000s are a bit more "airy," while the D5000s may have a bit more fine detail.
If you're into rock, metal, electronica, etc. - you'd likely prefer the AD2000s - just a cleaner, crisper sound, with more "bite," and fast, tight, clean impact. If you're into Jazz, and classical, or lots of acoustic sounds - you might prefer the D5000s - just a bit more "orgainic, texture" and "rich, liquid sound," and refined, subtle detail (that you hear in quite passages, not so much in loud, dynamic passages).
And... just to confuse you more... if you want a bit of both... you can always get the "new" modded HD580s, or HD600s - they're right in the middle of the two.
