Francoy
- Sep 11, 2010
Well after a week with a new Taboo to partner my lcd-2 (rev1), I can say it is pretty impressive :¬)
The pluses :
The juice is simply limitless. No matter how complex a passage may be the amp rumbles along effortlessly. It’s quick and agile (meaning the attack and decay are definitely a step up from my other amps).
Detail retrieval and extension are also impressive to my ears.
I find the lucid mode brings a lot to the table... I was a bit sceptic about it, but the out-of-head feeling it provides is pretty impressive (since it’s a switch, it’s very easy to compare with and without it). It definitely helps with placement and 3-dimensionality.
Now the minuses :
My unit has a bit of a hum to it... Although I have to admit I haven’t tried to resolve this with tube rolling, power management, etc. But I’m not sure I will be able to get rid of it completely.
I find that you need to have speakers plugged in to have the amp to make my LCD-2s sing. Otherwise, the headphones lose a lot of control and refinement. I know you can place resistors in each speaker circuits to simulate speakers and have the same effect has having speakers plugged in - will experiment with that and report back, because for me speakers are a bit of a nuisance (I use the amp in a work environment).
For my particular situation, a preamp is a must. The volume control on my amp seems a bit useless. If I plug the CDP directly the volume becomes incredibly loud with the slightest of movement of the knob (and has some channel imbalance). So the sound needs to be controlled line-level-wise for me to get rid of the channel imbalance and to offer some sort of control on the amp’s power. And maybe my partnering preamps are not that synergetic, because I need to EQ the sound a bit to get it to my liking (Although I admit I’m a bit of a bass-head).
So overall I’m pleased so far, but as you read It’s an amp that I had to « tame » to get it to work it’s best in my situation (And I might add that I still have a bit of taming to do). Will tube roll a bit and try some other combinations and report back my findings down the road...
The pluses :
Now the minuses :
