REVIEW : Burson Audio HA-160 with listening impressions
Jan 31, 2011 at 9:33 PM Post #31 of 85
nanaholic
I never gelled with the W5000 - but the W1000x is going down a storm!
If you can give your impression of it with the Burson that would be great.  I've always wanted to try a pair of higher end AT closed cans and was eyeing the W1000x at that price range.
Jan 31, 2011 at 11:47 PM Post #32 of 85
macbob713
Claremont, CA
I have a Burson HA-160 and when I turn the volume knob it slides and never makes any clicking sound. Sometimes if I don't turn the knob fully to the next stop, the sound will cut out in one channel. Is this normal? Overall the amp sounds superb but I'm a little bugged by this volume knob issue. Anyone had this problem?
Feb 1, 2011 at 2:26 AM Post #33 of 85
stainless824
Had the problem since day 1 where it loses 1 channel between steps. Thats just the stepped attenuator. Was a bit disconcertig coming from amps using potentiometers but used to it now. Stepped attenuators have less impact on the sound than the potentiometer does, its a much cleaner solution and only the best amps us them.
Feb 1, 2011 at 2:27 AM Post #34 of 85
stainless824
Lack of click however is not normal. Get it looked at
Feb 1, 2011 at 7:12 AM Post #35 of 85
MrSpenkelink
I'd appreciate impressions/opinions from those who have actually heard the W5000 paired with the HA-160 or HA-160D - thanks.
Feb 2, 2011 at 1:31 PM Post #38 of 85
soundaddicted
Okay then, how about Grado? Has anyone tried the HA-160 / HA-160D with the HF2, RS1i or PS1000?
[size=medium]A powerful Solid state amp such as the 160D wont have any problem driving grado's. [/size]
[size=medium]
You can check this
[/size]
Feb 4, 2011 at 2:08 AM Post #40 of 85
stainless824
In my opinion grados would be a tad too bright to be paired with the 160d but the w5000 would be a good match. Really depends because my music preferencea dont extend to metal or rock so if you're a rock fan then go for it. I would personally use those with tubes and the sennheisers, he6 and lcd2 with the ha160.
Feb 4, 2011 at 4:07 AM Post #41 of 85
leng jai
So after about 2 weeks of use I don't find the Burson and the D7000s to be a good mix at all. Bass is well and truly "boomy" on all but the best recordings, and the treble starts to grate slightly. It almost feels like its giving them too much power and all the frequencies are pumped up.
Feb 4, 2011 at 4:31 AM Post #42 of 85
leeperry
Galvanically isolated his brain
don't shoot the messenger...those Denon's are laughable IMHO. I briefly tried a d2k, it was terrible...even for $20, it would have been too expensive.
Feb 4, 2011 at 4:40 AM Post #43 of 85
MrSpenkelink
Thanks again but have you actually heard the W5000 and any of the Grado's that I mentioned with the HA-160? I really am looking for listening impressions and opinions from those who have.
Feb 4, 2011 at 8:14 AM Post #44 of 85
stainless824
Have heard the ps-1000 which is the grado sound signature in a nutshell so i'm making generalisations based on the 'house sound of the aforementioned brands. The w5000 however I used for a period of time before and after ha-160.
Feb 4, 2011 at 8:16 AM Post #45 of 85
stainless824
I think i mentioned that the d7000 was bass heavy somewhere and wouldnt go that well with the burson
