funkymartyn
Glad you liking the imp and topping amp....i also use the fiio e11k too....
Tonight I managed to resurrect my IMP which I thought was bricked. It was lying on bottom of my drawer for a long time from failed firmware upgrade and I thought it was brick as windows couldn't recognize it. I finally dared to try flashing it one more time, and got it working again.
I'm right now away from my imp so I can't confirm. I believe I downloaded it from agptek website but I think it wasn't that new firmware, something 2016 maybe instead. Imp isn't my daily player by the way, but maybe I'll update fw just to see any if there's any improvements. That will be however next week once I get back to my imp. One annoying thing that would be nice to have fixed, is with exfat format micro sd cards. Every folder has some unidentified file format replica visible on imp folder view and those files are at bottom on file list so there's always 2x amount of folders you actually have which makes navigating slower. I believe with fat32 format imp doesn't show those replica files.That's great!
I just noticed that AGPtek released a new firmware on 9/7/17, is that the one you wound up installing?
Downloadable here - http://www.agptek.com/blog/?p=1431
Have you noticed any enhanced functionality?
I briefly tested my Sandisk Ultra 128gb micro sd on my IMP, and it seems to be working very well. I used only folder view mode since I didn't want to scan the database. There wasn't any lag when browsing through the card, and songs started right away. Works surprisingly fast in fact, I scrolled around my music library and song starting didn't lag at all, not a single time. I have almost 5000 songs on card, most are cd quality flac but there's also mp3. I have cleaned most of not so important metadata of my music files and don't have any album images tagged to songs either.Has anyone tried a 128GB or 200 GB card on the IMP? I use flac only on my players and would love to load more albums on this. Sometimes older players don't mention larger sizes because they did not exist when it was designed. I would be using folder view anyway so I don't care if it is unable to create a large data base.
