roadcykler
- Jun 28, 2009
Nevermind. No idea what happened but I deselected the 64 bit versions and it seems to have worked, for now.
The VST adapter for Foobar works with 32 bit only. Glad you got it to work.Nevermind. No idea what happened but I deselected the 64 bit versions and it seems to have worked, for now.
Am pretty new to this so please bear with me. Will the Foobar+DSP work if I am using a line out to an external DAC?
Very interesting, I’ll definitely be giving the equalizer APO version a shot once I’m back at my main system (on vacation for the holidays).
I’d like to add my voice to the choir asking for an iOS version of this plugin if at all possible as I will likely be setting up a nighttime listening station with an iPad on music transport duty.
Thanks for the quick reply! I had a feeling that was the case. Hopefully you guys release a desktop dac/amp/DSP box in the future that can store Reveal settings...a “Cipher Block” if you will.A plugin that can do system wide convolution/presets etc on iOS or Android would very likely require a Root or Jail break unless Android and Apple start supporting a potent DSP engine at the OS level for system wide use. One reason why you do not see many apps that already do this. The alternative is to create our own Music App, which would be a huge undertaking and it would still not be system wide.
For your specific use case, to get the presets on iOS, the one alternative you have is Roon. Roon now supports iOS playback, a Roon core can do the presets and stream to the iOS endpoint connected to a DAC/Amp.
When you engage the DSP engine in Roon, it is recommended to set the Headroom to -3dB, this would prevent any clipping. An alternate option is the automatic volume leveling which would play all tracks at a similar loudness and would also likely prevent clipping.One thing I noticed with the Roon preset for the LCDi4 with the Linear Filter is on high frequencies their seems to be a slight static noise. It's gone though once I set the "Volume Leveling" setting to Auto.
Good to know this worked out for you and thanks for your feedback. We will update Reveal and Roon with dedicated LCD2c presets near end of Jan, but LCD2 presets should work too depending on your preferences.By the way, I remembered I have my laptop with me, so I got it set up with equalizer APO and it’s pretty nice so far. I’ve only been listening to it (with the LCD-2 preset on my 2C’s) for a couple minutes so I’ll hold my impressions for now, but first impressions are positive. I appreciate Audeze taking steps to acclimate the high end market to DSP, I really feel as though it’s the future.
I am still searching the location of .VST on my MAC. Please helpNevermind. I just found it...
You will find them here:I am still searching the location of .VST on my MAC. Please help
Macintosh HD:/Library/Audio/Plug-Ins/Components/ (AU)
Macintosh HD:/Library/Audio/Plug-Ins/VST/ (VST)
But you may have to access the hidden folder and to do you may have to type the following in the terminal:
defaults write com.apple.finder AppleShowAllFiles YES
