tjstyle
- Feb 6, 2016
Thank you for the feedback, LED notification is make me easy to find the problem.
So here is the update for Random mode playback problem bug fix:
https://revampacoustics.com/download/P1/P1_V2.0.4.zip
EDIT: Sorry need to mention this is beta firmware to test
I agree that so far, the 1.9.0 firmware seems to be the best except for the random mode needing some improvement.. So far, I have found that none up the updates above 1.9.0 allow random play to be selected. Hopefully, TJ can address the random play issue and improve its "randomness" in all the firmware versions.
I get the 3 purple flashes for Random mode, but no music plays. I tried the reset and got the 3 Cyan flashes OK then turned off and did track back while turning on, got 3 purple flashes but still no music at all. Player is unresponsive and no buttons work until I turn it off and back on again, then it just plays sequentially. Guess I will go back to 1.0.9. again, as it is working fine.
