Replacement Power Cable for ALO Audio Studio Six
Aug 30, 2024 at 11:09 AM Thread Starter Post #1 of 6
samueln
Brooklyn, NY
Hi folks :wave:
I was recently gifted a used ALO Audio Studio Six Amplifier + Phono Stage, and I’m thrilled to add it to my audio setup. However, I’m missing the power cable that connects to the 5-pin input (see bottom right of the image below), and I’m not sure if it’s a standard cable or something custom-made for this model.
I’ve tried contacting ALO Audio through email and Instagram for a copy of the manuals or any details about the cable, but I haven’t had any luck hearing back from them.
If anyone has experience with this amp or knows what cable I should be looking for, I would greatly appreciate your help. Thanks in advance!
Aug 30, 2024 at 12:19 PM Post #2 of 6
Sep 5, 2024 at 12:52 AM Post #4 of 6
For something that rare, try contacting any dealers still selling the phono stage to see if they can get an accessory power cable for you. They may even be able to tell you about it to find a comparable spec cable if it's not available. If one has a manual they can send, that might have all the info you need.
If you do a search here:
ALO audio umbilical power cable
That type of cable is an umbilical, and there's several places that make them. Reaching out to them may be even better if they've made one for that combo in the past.
Sep 10, 2024 at 10:50 PM Post #5 of 6
Thanks, that’s a great idea! I’ll give that a try and reach out to some dealers to see what they can offer. I did get a version of the manual, but unfortunately, it doesn’t provide any details other than mentioning an accessory power cable...
Appreciate the suggestion!
Sep 13, 2024 at 10:09 PM Post #6 of 6
Looks like a "HiRose 5 pin" cable.
