Replacement pads for ksc-35
post-170091
Thread Starter
Post #1 of 9
SRV
i jusr got in my ksc-35 the other day, and while iam pleased with their sound , i am concerned about one thing. The pads pads on these things don't seem to be as furable as the ones on my ksc-50 so this leads me to believe it won't be long until they wear out, as i am very rough on portable headphones. Does anybody know where i can get replacement pads once these things wear out?
post-170144
Post #2 of 9
HighwayStar
Won't excrete urine on your holiday (unless you do so to his first).
Looks like they're $5.00 at Koss.com. No shipping was added when I went through the motions. You'd probably find something close (enough to use) at Radio Shack cheaper...
post-170157
Post #3 of 9
SRV
Thanks for the help, but i looked around on the koss sight and i couldn't find anything about replacement pads there. Anyway you can help me out with a url or a link maybe?
post-170159
Post #4 of 9
HighwayStar
Can't seem to link to it, but just click on Customer Service, then Order Replacement Ear Cushions. Scroll down till you see the KSC-35...
post-170177
Post #5 of 9
SRV
ok, i found it. Thanks for the help highwaystar, i really appreciate it.
post-170394
Post #6 of 9
Ebonyks
If you ship them out to koss, they'll replace them for free. Living 5 minutes from koss world headquarters has it's perks
post-170453
Post #7 of 9
HighwayStar
I live 5 minutes from Grado. Now all I need is Etymotic to move into the neighborhood
post-170720
Post #8 of 9
millerdog
radio shack
post-170760
Post #9 of 9
john_jcb
This is a customized witticism.
Etymotics just down the road a bit from me. Wonder if they have an outlet store like Evon's Nuts which is close by.
