Replacement pads for HD600 or similar
Jan 9, 2018 at 5:24 PM Thread Starter Post #1 of 4
mandello
italy
Hi to everyone, i need to replace the pads on the hd600, at the moment i think that the originals are too expensive for me, i've seen lots of pads on ebay for 10/15€, do someone tried it and can suggest me wich to buy (links are welcome)?
Do someone tried other pads on the hd600?
Every tip is welcome!!!
Jan 9, 2018 at 11:39 PM Post #2 of 4
Brainwavz HM5 earpads will fit and you have several options. I use the angled velour.
You just need to gut your original earpads and fit the HM5 sleeve over the plastic mount on the Sennheiser pads so you can clip them onto the earcups.
Jan 10, 2018 at 9:42 PM Post #4 of 4
Ok, HM5 earpads could be a nice choice, but nothing about the standard pads?!?!?
for the price difference I wouldn't gamble on the no name pads when the Brainwavz isn't that much more expensive and so far the foam is holding up. I've been using mine for a year and it's still fairly stiff. Not that it hurts using them but they aren't getting too mushy (they feel softer out of the box vs the original Sennheiser pads), so it seems these will last longer.. Cut it properly so you can mount and remount on the Sennheiser pads.
Cheap generic pads look thinner than the stock pads too.
