- Jan 9, 2003
I have this Singlepower SDS "toaster" prototype amp that is some 20 years old. I'm aware of the safety warnings concerning these amps. Around 2009, it had upgrades which included Rubycon Black Gate output caps. There are 4 each of the following coupling caps on output:
Blackgate WK POWER TANK: 220uF, 200 WV (Working Volts) rating, Non-Polarized Electrolytic, 30mm Diameter x 25 mm Length
IIRC each audio channel has 2 of these wired, in SERIES, to cover 400 working volts (the tube plate voltage) - any lower rating will absolutely not work. These Black Gates are now completely un-obtainum. I also recall they sounded a LOT better than other electrolytics. This particular amp has been completely reliable & without problem. But as it's ageing, I wonder about my options for replacing those caps, without reducing sound quality. I'm also just curious what the options today look like. There's room for slightly larger caps, but not too much larger.
Would something like a Mundorf Mcap Evo Aluminum / Oil be a good idea? They go up to 100uF @ 350 Vdc, and it's a film cap that's actually small enough in size to work here. If I only use high impedance headphones with the amp (> 300 ohms), then 100uF should be enough. Or, what about the Audio Note KAISEI electrolytics (by Rubycon), which have a 220uF 350Vdc model? Does that look like the most direct replacement for my Black Gates?
Or are there any other ideas I should look into?
Pictured is the OTHER prototype SDS I used to own (this one is very similar but slightly different). The old one shows its two "upstream" Black Gates have been replaced by plain Nichicon 390uF @ 400 WV. Yes, there was a "not nice" reason they were replaced . The two downstream Black Gates remain. All 4 output caps can be seen zip-tied to the bottom rail. The Nichicons are larger and brown.
I know this is crappy work; just looking for opinions on caps please
