BowerR64
- Aug 23, 2004
I got an older set of eggos (D-77) and they started to short out a few years ago. I want to try and replace the plug in cable. Where can i get a fairly long Y cable? I want it to be atleast 3 meters long, decent quality with a right angle plug.
I didnt think of it till i got my D22s and it had Y cables directly to each can. It might be easier to just drill little holes and hardwire the Y cable to each can then to try and rewire the whole thing. Depends on the price and avlability of the cable what i will do.
This is what the cable looks like, its 1/8" mini on one side and the other i dont know What it is. Im not even sure if its the cable side plug or the female in the phones?
