tradja
- Jun 1, 2004
I don't know how many of you might have been following the catastrophic saga of the Little Dot II tube amp group buy over at ipodstudio (http://ipastudio.com/forums/showthread.php?t=1862), involving a ~75% failure rate of the amps in the group buy. (The failures start cropping up around page 22 of that thread)
In any event, I want to upgrade the caps in my amp before they blow. I am reasonably competent with a soldering iron, but would probably just have it done by a shop here in town or at least let the caps discharge for days. The caps that are blowing are rated 330uF @ 250 volts, photos of blown caps here.
My question is, based on what's happening to these caps, what would be a good cap to replace them with? Any info is greatly appreciated!
