Remove hiss?
Discussion in 'Sound Science' started by PDVJAM, Jul 10, 2019.
  1. Davesrose
    From what I've read, there's also a lot of desktop amps that have irregularities with IEM resistance/sensitivity to cause a lot of hiss as well. My only IEM is my workout BT earphones (probably a great format that eliminates any of those issues). I would think that if you're determined to use any source, it would be possible. The main issue is sensitivity to resistance. Would be a good DIY to research your amp output vs IEM specs (and then determine what resistor to use in a makeshift adapter).
  2. PDVJAM
    Well, my IEMatch has arrived and I'm happy with it, can't hear hiss anymore. As to frequency response of CA Solaris - there are some measurements in Solaris's thread - iEMatch brings very small changes to original response.
    bigshot likes this.
  3. castleofargh Contributor
    happy to see that you found a satisfying solution.
