amphead
- May 5, 2007
Thought I would share this with whoever might need it. I put a latching relay, with contacts close to my 9v battery and the vcc pin on the opamp chip. This means that I can power on from the panel switch and still keep the local current source path short. I did a pre and post listening test. I noticed greater presence and detail using the relay, as opposed to running a longer current path to the panel switch, and then to the chips power pin. If you are using batteries make sure to use a latching relay, otherwise a non-latching will consume too much power in the coil.
