Recommendation for a wired+wireless with great voice call quality for work
Nov 16, 2022 at 5:59 PM Thread Starter Post #1 of 2
Vg12th
Switzerland
Hello all,
Looking for some recommendations for a headphone with these features:
- wireless + wired. I will use it for work, so it is important that I can move around with it when connected to phone, and be able to connect to my desktop.
- Very good voice call. Will be used for zoom meetings.
- Portability would be nice, good case.
- google assistant compatible
- does not need the best anc
- budget <$300
I would appreciate your opinions on headphones that best fit my ask. Currently I'm looking at Shure aionic 50. I hear a lot about the sony xm4s but also that it's mic is pretty bad?
Nov 16, 2022 at 10:03 PM Post #2 of 2
Not a direct answer to your question but something to take into consideration.
For Zoom, I use the Philips SHP9500 (and X2HR prior) with a V-Moda Boom Pro mic. What I learned from using closed backs was that if they didn't have sidetone, I couldn't hear my own voice on calls, and was guessing as to how loud I was speaking.
Sound doesn't bleed into the mic at moderate volume.
