Recommend Bluetooth/NFC Earphones or In-Ear Monitors for PS Vita and an NFC enabled Phone
post-9302744
Thread Starter
Post #1 of 2
Jemi200
I want portable bluetooth earphones or In Ear Monitors for my PS Vita and NFC Phone.  Preferably an NFC chip in them too for phones with NFC.  Nothing too expensive, somewhere I'd say at a $150 max.  Basically I play games and would listen to music / streaming video on my phone.  Something that looks sleek, as well.
The music I listen to is electronic and some hip hop.
If there are no bluetooth earphones / IEMs that are portable, then I understand.  I would then ask for Portable Headphones from you.
Thank You
post-9304352
Post #2 of 2
TwinQY
Something about the rear end of a cat
Cat
Cat
Well first off - http://www.head-fi.org/t/596233/buying-portable-or-in-ear-headphones-seeking-guidance-dont-start-a-new-thread-ask-for-advice-here
Ever thought of a bluetooth dongle as an alternative? Something like this (yes it's unavailable, just giving an example) - http://www.amazon.com/Samsung-Stereo-Clip-On-Bluetooth-Headset/dp/B0057WWK5E could work just as well with the proper adapter, really isn't added hassle as the setup would be similar in idea, and you get a much wider plethora of normal IEM choices.
Genres are helpful, but stating sound preferences/signature preferences, comfort, isolation, build, etc would be helpful.
