judgmentday
- Feb 18, 2003
Vinyl is a constant signal, transistors are turning on and off devices that only translate 0s and 1s in analog signal to give an idea of real music.
Sorry, judge, but statements like that blur your credibility
Guess what reproduces the better sound?
In your opinion! Perhaps someone else thought that the CD sounds more like the original master, whereas the record adds euphonic coloration.
LP is already an analog signal just needs the right amplification,
Both analog and digital music go through massive amounts of processing between the time the musicians played it in the studio and your speakers play it in your home. Both processes include phase and time-delay shifting equalization, and compression. Processing for records includes manipulating low frequencies towards the center, equalizing to and from RIAA standards, and compressing peaks so as not to send the stylus into the air. Digital processing includes ADC-DAC conversions, high-frequency filters, bass boost, treble boost and volume boost "just because we can!"
Enlighten me if I'm wrong. I do really appreciate your knowledge. Let me ask you this: If the same master is dumped in the two formats, (CD & LP) should not the sound be exactly the same, minus the background noise or physical limitations of the turntable/LP? If the mastering is exactly the same, I can understand why you like more the CD. Obviously you are not going to hear a needle ha, ha, ha. I don't know the technicalities about mastering and recording but so far, when I compared the same performance on LP vs. CD, it was very clear to me that the LP sounded much better. Now I ask you, why the LP is $70.00 and the CD is only $7.00?
