I am still having issues with my EarStudio as I cannot change anything on the Audio Output Mode page (where one selects the type of output, SE, Bal, 2x, etc.) It is greyed out and whenever I try to return via the back arrow, the app stops. This happens on v1.17 and also on the latest v1.19 firmware. I think my app is the latest version as it updated fairly recently. Anyone else having this problem?
Do you still have the issue?
Can you send us the screenshot of the app? (to: support@radsone.com)
FYI,
When 3.5mm jack is connected, you cannot select any of the 2.5mm output modes.
The 2.5mm balance mode can be selected only in case 3.5mm jack unplugged.
Please contact support@radsone.com, if any issue with ES100.
Thanks and Regards,
WS
FYI,
Thanks and Regards,
WS
After much testing and experimentation, I found the issue for some reason only happens with my Galaxy S4 phone despite using the latest firmware and app version. My ES100 and App are working just fine with other sources.
"Hello,
Sorry but we're still working on it.
ES100 on AMAZON Europe is going to be available within a couple of weeks,
and will be shipped directly from AMAZON Europe warehouse upon your order.
Thanks,
WS"
Anyone have a recommendation for a female 2.5mm to 3.5mm male adapter I can use?
I have my balanced 2.5mm cable to connect to my EarStudio, but when I want to connect to a 3.5mm input is like not to have to switch entire cables.
I did order 2 separate ones from AliExpress however that was over a month ago and still haven’t received them. Luckily they were about $3 a piece so not a big deal.
No worries. Some brands (Hifiman and LH Labs for example) uses 3.5mm balanced output on their players/DACs but to use your 2.5mm terminated balanced cable with a phone or any other single ended source you'd need the regular 3.5mm male. I hope that makes sense.
I just ordered one. I also have a balanced cable question.
I have a Trinity iem which has a 3.5mm female balanced end.
What is the shortest cable I can use? I assume I would need a 2.5 to 3.5 male to male balanced cable.
