Radsone EarStudio
Discussion in 'Portable Headphone Amps' started by m4rkw, Dec 12, 2017.
47 48 49 50 51 52 53 54 55 56
58 59 60 61 62 63 64 65 66 67
  1. PantsUK
    YEP EUROPE .... or selfishly the UK PLEASSSSSSSSSSSSSSSSSSE ....... was told March, then April ...... it is April how are we looking?????
  2. waynes world
    Hi @wslee, I think I'm having the same issue. My phone is S7 edge android 7. The es100 is on firmware 1.1.9, and the app is the most recent.
    What happens occasionally for me:
    - turn on es100 and the phone connects to it.
    - go into the app, and it says "must force restart" (or something similar)
    - once the app is restarted, the "device search" in the app says "connection failed. please try again"
    - note that at this point, the es100 functions fine. It's just that the app can't be used.
    - and at this point, the only way that I have found to then rectify is, while still in the app, to turn the es100 off and on, and then the app automatically finds it.
    Let me know if I can provide any further info. Thanks.
    wslee and DBaldock9 like this.
  3. tim0chan
    I probably shouldn't update then....
  4. waynes world
    It was happening for me with the previous version as well (it just took me this long to report it).
  5. tim0chan
    I see, I will still hold off till u get it resolved...
    Maybe u can reset the unit? Not sure how to do that tho...
  6. Coconut Wireles
    I updated the firmware with no issues so far on iPhone 7 Plus.
    I feel like I read WSLee say earlier on the thread that holding all 4 vol and track buttons simultaneously while powering on resets it. I would probably just double check that before you try.
  7. Jearly410
    No issues updating to latest firmware with iPhone 6s+
  8. parawizard
  9. sfoclt
    Question:
    I can connect to my iPhone via bluetooth and use the app.
    Should I be able to connect to the bluetooth from my tv, for example? The device isn't showing up to connect so thought I'd inquire here. Thx.
  10. Coconut Wireles
    I don't see why not. I was wondering that recently too but haven't had a chance to try it with my television yet.
  11. sfoclt
    Perhaps I’m doing the pairing incorrectly. Just got the device this afternoon so working through set up. Working great with the iPhone though (and Roku app on the phone, although I’d prefer to try connecting directly to the tv if possible).
    wslee likes this.
  12. wslee
    We're working on it.
    Hope that we can add it in the next F/W update sooner or later.
    Thanks and Regards,
    WS
    tim0chan and Soaa- like this.
  13. wslee
    Thanks for the kind input.
    We'll check what you reported shortly.
    Thanks and Regards,
    WS
  14. Researcher
    any update sofar for " boom sound"?
  15. sfoclt
    Just to update: I’ve been able to connect to everything I’ve tried now, including the tv.
