@yoowan:
May I ask at which volume levels do you listen with those IEM?
If your headphone amplifier doesn't have an adjustable gain option like PGA(Programmable Gain Amp) or low power mode,
you will need to get the volume lower down in the digital domain,
which results in more loss in LSB with the 115dB IEM than the 102dB IEM and may cause what you called sound artifacts.
High power headphone amplifier without any analog gain control option would not fit high sensitivity IEM, for the above reason.
Thanks and Regards,
WS
