- Sep 28, 2016
Lol I can't seem to charge my es100 by portable charger
Just wanted to share that I finally received these 2-Pin 50cm cables https://www.aliexpress.com/item/cus...32852715561.html?spm=a2g0s.9042311.0.0.TMCYTU
They work with both my iSine and Massdrop Plus IEMs and will probably work just fine with KZ and Noble Audio IEMs. I also ordered the DIY version with no connectors and will solder on my own. I already made a short cable but these look better than my DIY version haha. I will probably chop off the 3.5mm SE connector and put on a 2.5mm balanced for use with the ES100.
These are a good length for attaching to the ES100 (or BTR1 or similar device) to the upper front of your shirt.
I ordered these
https://www.aliexpress.com/item/KZ-...32842791429.html?spm=a2g0s.9042311.0.0.0JQ2nE
and these
https://www.aliexpress.com/item/Are...32842493748.html?spm=a2g0s.9042311.0.0.sBZ0p0
They arrived yesterday quality seems really good (connector that is not the cable that hasnt arrived yet)
- The buttons are tactile but not tactile enough. It adds to the profile, but it would be nice if the volume rockers had some angle to press down on to, or protrude them out a little more. Its a bit easy to press the wrong buttons, especially since its very cramped between the buttons and the headphone jack. Headphone jack on the side opposite the USB would have probably helped in this case. I find that just the way I hold and press the volume or track skip buttions, I accidentally press the buttons on the opposite side (i.e. I go to press Volume Up and I press Skip Track as well since I'm gripping the other side to press volume
Thanks for the posting.
The answer above seems to be from the other unknown and we've made an official answer for that:
According to the specification of the battery in ES100,
the cycle life guarantees 300 cycles, keeping more than 80% at standard charge/discharge.
If you have it charged/discharged every other day, it seems the only 80% of the battery capacity will be available after two years.
But it doesn't mean it won't work at all after two years.
Also when connected to USB charger or PC, ES100 works with the power sourced from USB VBUS, not by the battery.
Thanks for pointing it out.
Regards,
WS
Thanks for that information. Is the "cycle life guarantees 300 cycles" statistic basically the same as with other similar batteries/devices?
Do you think that the battery could be replaced? In a few years I'll probably want to buy the latest/greatest Earstudio anyway, but it would be nice to also have the option of continuing to use the ES100 as a backup.
Thank you for your thorough investigation. I suspected it had to do with the filter setting and I was about to take some measurements myself, but you beat me to it.So I did much more tests and found the issue.
Slow Digital filter makes a lot of audible Harmonics.
It also cuts frequencies above 8kHz too fast and make -3dB vs normal range.
Don't use Slow Roll Off - bugs are there.
Short Sharp is 10dB lower THD than Sharp, so IMHO that's the only option that should be used.
Load makes -0.2dB drop of FR in mid-range, 10 times THD increase and pushes stereo cross-talk to -45 vs -85dB.
DCT makes a weird +0.2FR deviation.
Pictures tomorrow.
Unfortunately, my knowledge of DSP theory is not enough to make this call. Somehow I didn't noticed change with filter settings and that's why I just contacted manufacturer who asked me to send screenshots of all my settings and then didn't tell me filter is the source of problem. At the same time I didn't notice because aptx noise easily gets saturated and makes random pops and clicks - this thing is not cured by filter setting. I have a feeling that I even have to decrease digital volume despite recommendations of keeping it maximum.Thank you for your thorough investigation. I suspected it had to do with the filter setting and I was about to take some measurements myself, but you beat me to it.
I've had mine on the symmetric sharp roll-off filter to preserve linear phase.
In my opinion, offering the slow roll-off filters is a mistake as they measurably degrade the signal. The aliasing they introduce isn't a bug -- it's just basic DSP theory. Any signal above Nyquist will get reflected back into the audible range.
I believe you didn't see problems with the AAC due to some combination of the following:
- BT AAC operates at 44.1 KHz, which means no resampling, and as a result, no aliasing.
- The AAC codec itself has a sharp roll-off filter at around 18 KHz, which means the signal is already narrow-band, so even if the ES performs some kind of resampling, there isn't any content above Nyquist frequency, so no aliasing.
I agree. Also, one button I am often looking for is the power/play/pause button, and it takes some concentration. It would be nice if it was a bit more prominent, or better yet, on the face of the device (like with the BTR1 shown in your picture).
That's pretty much the only niggle I have with the ES100 so far though - everything else is brilliant
the different digital filter setting is really noticeable to my ears, especially noticable on the attack of the song kinda like compression effect, I only like the short delay sharp roll-off as it's the most natural sounding to me (less pumping and not flatten the attack too much
