MonoJon
Wow, some people in this thread are getting way too worked up over nothing! Yes, the rebooting behavior when the ES100 is connected to or removed from a charger is a design flaw and is annoying. Yes, it also has many redeeming and even unique features that more than make up for it, but that doesn't mean that it's not still annoying, and it doesn't mean that @radsone shouldn't fix it in the firmware or in the next version of the device if they can.
Many thanks or this! The cable may be too expensive for me, so I might prefer to have my hand at making one. Someone on the K275 thread mentioned a method for making a cable using a certain A/V spooled cable and a paracord Aleve, but when I asked about a link to detailed tutorial or instructions, they didn't respond. I hope to mod my K275 to make them balanced and add a 4-pin mini XLR (there is a tutorial for doing this online).
This is the cable I ordered for AKG K712 PROs. Maroon / Black Rean / 20 cm / 3.5 mm gold Rean jack.
They used to list "Original Sennheiser 598 cable modded to balanced and cut to desired length" item / option in their list, but since there is a "national stortage" of those cables at the moment, it is missing from their webpage. I asked for one (via email), and it took them 3 days to find and buy one from unofficial source.. I ended up paying 36 GBP for it (including all the work and new TRRS source connector).
They'll make any length cable you need, at least as short as you need, but since they do not list every possible length in webstore, just gather all the info / options you need and send them email. Once everything is clear they'll send you a PayPal link, you pay and wait for the goodies (seriously, I got a biscuit with my cables ) to arrive.
EDIT: About the cable quality. I was told that Pellucid Plus cable is better, but "for such a short cable I don't think there would be a noticeable audio difference, especially with the signal being partly wireless", so I actually got recommendation, from OIDIO, to order the cheaper Pellucid cable. They didn't suggest Mongrel for such a short cable either.
