monsieurfromag3
I so feel you, man.Thanks for the info! I agree with your assessment of the BL03, which is why I've been wondering if I really need to spend the extra $ on them, when I already own and like my KPE. As for the ES100, I don't know. I wish it worked right OOTB, and I didn't have to send it back. I don't like to have to try to forcefully make stuff connect...especially with a device like this, which to me feels fragile because it's made mostly of plastic. I guess that's what it all comes down to in the end, for me. I really love the robust build of my Fiio Q1MK2 dac/amp. The SQ is crazy good...so much so that I can't justify spending more than a half months income on a DAP with a high quality balanced output...to achieve the same or MARGINALLY better SQ. Only problem I have with it, is it's a cumbersome stack when connected to my smartphone, especially for portable use; because I need to use a short OTG cable to connect it to my phone, and I need to attach the Fiio to the back of my smartphone case with 3M Dual Lock to make the screen usable. Every 3 months, I need to replace the 3M Dual Lock with new strips on both units, to keep them secured to each other because of dirt and grime getting into the locking grooves. This becomes cumbersome and expensive, with a roll of Dual Lock running me $30+ for a 10 foot order. The other problem is that, while I have this stack connected, I can't use the rear camera on my smartphone because the dac/amp covers it up. So, to sum it all up...what I desperately want and need...is a high powered, low noise, Bluetooth dac/amp with 2.5 balanced output, that I don't need to physically attach to my phone so that I can still have all the functionality of my phone, camera included. The ES100 seems to be that, from all I have read.
The stack thing - went there, it was a nightmare. Just not functional in any sense - connection was unreliable, my phone became an unwieldy monster, and with the Q1MkII form factor it’s even worse since it obscures the lens... plus what you write about the 3M expenses, I mean, seriously, stop doing that to yourself
You have plenty of gear already, so I don’t think your Ali basket will bring as meaningful an upgrade to your listening experience as the ES100 will. It’s seriously transformative! A much better solution than a dedicated DAP with all the shortcomings those have. I have a V30, which is like a great midrange DAP and a fully functional phone rolled into one, and even that elegant solution is often less desirable than using the ES100.
