Radsone EarStudio ES100
Discussion in 'Portable Headphone Amps' started by m4rkw, Dec 12, 2017.
342 343 344 345 346 347 348 349 350 351
353 354 355 356 357 358 359 360 361 362
  1. Slater
  2. subwoof3r
    That would be nice if we can get a confirmation from @radsone
  3. Slater
    Agreed. Because I’m fairly sure that I have gotten the pop up warning (about not removing the jack while music is playing) when the output was locked.
    subwoof3r likes this.
  4. Lurk650
    Yes, you always have to force the LDAC "Optimized for Audio Quality" in Dev Options. I just leave it at Best Effort as I can't hear a difference anyways.
    For always using LDAC go to your Bluetooth settings menu, click the Earstudio wheel cog then select LDAC so it will always force LDAC.
    pitsel, peter123 and scotvl like this.
  5. Broquen
    Maybe rooting and editing build.prop (if it still exists on Android devices).
    BTW you can know if best audio quality is selected because signal drops quicker and there're sound interruptions. With auto selected it remains stronger and more distance and/or physical barriers are needed to loose signal.
    scotvl likes this.
  6. vurtomatic
    Noticing some odd "bugs" or behaviors over time. After turning it on and connecting to my Android phone, the app doesn't acknowledge the ES100 is on. Today when I turned it on,
    the indicator light remained a steady green and won't connect to the phone. This was solved by charging it, but connecting it to the phone, same issue with the app.
  7. radsone
    EarStudio Stay updated on EarStudio at their sponsor page on Head-Fi.
    https://www.facebook.com/radsoneinc www.twitter.com/radsoneinc https://www.radsone.com/earstudio support@radsone.com
  8. Lurk650
    Yes, but every time you disconnect from the ES100 you have to change the setting for Best Audio
  9. rkw
    The only way around that is to root the phone and modify the Android system.
    zolom likes this.
  10. vurtomatic
    Just saw on massdrop for $79, free shipping within US.
  11. NWLierly
    I almost lasted a month without mine after the replacement unit they gave me in April died last month - the Drop for $79 made me realize how badly I wanted one in my life again... *sigh* Amazon it is - I so wanted to have the patience to see if the BTR5 was going to be competition for the ES before I bought in again... this why we (I) can't have nice (expensive) amps.
  12. dacari
    Yesterday I updated my Pixel 3a to Android 10 and now it doesn't recognize my ES100, previous version was smooth, receiving LDAC 24/96 without forcing nothing, out of the box.
    Anyone is having this problem?
  13. maniac2003
    No issues on my Pixel 3 with Android 10.
    Connected first time.
    dacari likes this.
  14. Slater
    Maybe try deleting the App and Bluetooth pairing and setting it both of them back up?
    dacari likes this.
  15. acygni
    Didn't the btr5 already shown it has better hardware? Shanling also just announced their Up4 which has identical specs as btr5 but uglier and hopefully cheaper
