Radsone EarStudio ES100
post-15161658
Post #5,251 of 6,070
Jearly410
San Antonio TX
San Antonio TX
Based on that guy’s description, my money is on a cold solder joint. When bumped, it makes an intermittent connection and resets or shorts out and shuts down.
If anyone has a bad one they can send me, I’ll open it up and see if it can be fixed easily. It sounds like such a fix could benefit a lot of people.
PM me if anyone is able to help!
Pm sent!
Reactions: Slater
post-15161662
Post #5,252 of 6,070
Slater
Cincinnati, Ohio USA
post-15162215
Post #5,253 of 6,070
Jearly410
San Antonio TX
San Antonio TX
Have you been flying with it? Has it been exposed to large changes in temperature/pressure/humidity?
No flying, no changes outside of the ordinary.
post-15162403
Post #5,254 of 6,070
subwoof3r
France
France
Interesting discussion, so if understand well, let connected 24/7 the ES100 via USB cable as a DAC for computer is finally a bad idea (even if the battery care option is turned ON) ?
Also, another question: even if we properly lock the output, doesn't mean we are safe of shorts when removing the plug while listening to music ?
post-15162779
Post #5,255 of 6,070
Slater
Correct, it is not safe to remove or insert the plug while music is playing. It doesn’t matter what settings you have set. It is due to the hardware design.
post-15164314
Post #5,257 of 6,070
davehutch
Website
www.hutchinsonphotographic.com
Unless you lock the output. Then it's ok
post-15164334
Post #5,258 of 6,070
zolom
Here
Here
Hi,
Is there a method (procedure or application) to set immediately the "Bluetooth Audio LDAC Codec: Playback quality" under Developer Options to the relevant selection without having to go (again and again) into the long Settings sequence hierarchy?
Thanks
post-15164337
Post #5,259 of 6,070
WilliamLeonhart
Vietnam
Vietnam
Hi,
Thanks
Are you referring to Android? I don’t think there is
post-15164338
Post #5,260 of 6,070
subwoof3r
France
France
Hi,
Is there a method (procedure or application) to set immediately the "Bluetooth Audio LDAC Codec: Playback quality" under Developer Options to the relevant selection without having to go (again and again) into the long Settings hierarchy?
Thanks
If your source device has LDAC, normally it should be "outputed" automatically on LDAC. You shouldn't have to make any choice.
ES100 should select (or force) LDAC directly.
post-15164358
Post #5,261 of 6,070
zolom
Here
Here
Thanks
It always defaults to "Best Effort". I did perceived "Optimized for Audio Quality" as better sounding
post-15164365
Post #5,262 of 6,070
subwoof3r
France
France
Thanks
Always check directly via EarStudio app the real bluetooth input, best way to be sure it's playing in LDAC mode :thumbsup:
post-15164387
Post #5,263 of 6,070
zolom
Here
Here
Yes, my ES100 is always set to LDAC (96/24), but on the phone side (S10) it can be further configured to the desired LDAC Playback Quality level (under developer options)
post-15164414
Post #5,264 of 6,070
subwoof3r
France
France
Always better to let all options as default, so you can be sure ES100 will handle the best of your device input anyway.
Reactions: zolom
post-15164461
Post #5,265 of 6,070
moisespr123
United States
United States
Website
moisescardona.me
I also manually set the LDAC quality to "Optimize for Audio Quality". Doesn't that forces the device to stream at 900kbit? I've never had an issue setting it that way for the ES100. And it sounds great too.
Users Who Are Viewing This Thread (Users: 1, Guests: 8)
  • Top
