Radsone EarStudio ES100
post-14962484
Post #4,651 of 6,241
RadarJammer
Right now it's just wishful thinking - Radsone hasn't given any indication of a followup to the ES100 to my knowledge.
Radsone hasn't done anything at all since early January, except some little tinkering with their facebook appearance. One might as well consider them dead.
BTW, it is really disappointing that Microsoft has done nothing to implement better Bluetooth audio encoders than SBC into Windows. Everybody improves on Bluetooth, Google managed to get the LDAC encoder licence free (I believe, while the decoder remains licenced) from Sony and implemented it and AAC, aptX and aptX HD by default into Android 8 Oreo, thus I had hopes about something like this on Windows - but nothing.
Meanwhile the Android smartphone manufacturers use the LDAC as differentiation feature among phone classes. Now even Sony reserves LDAC for its top models only. Same with the new Pixel 3a without LDAC or middle class Huaweis without that encoder.
post-14962575
Post #4,652 of 6,241
backdrifter
Hi, everyone. I'd really appreciate some help understanding the operation of this thing. I'm using a Galaxy S9 and the Hiby player to play back flac files of my CDs, but this behavior doesn't seem dependent on the player.
If I have the phone's Bluetooth on and I plug in the ES100 direct through USB, the EarStudio app says I am connected using Bluetooth with LDAC 24/96. Why doesn't it say I am connected through USB?
If I turn off Bluetooth on my phone, the sound cuts out and returns louder and with better quality, but everything on the EarStudio app home screen is grayed out except for source volume. Why doesn't it say it's connected through USB? The volume buttons on the ES100 still work. Under what circumstances will the app show that it is connected via USB?
If I choose "Exclusive HQ USB audio access" on the Hiby player, I get silence. Is this typical?
Thanks for any advice you can offer!
Since no one has tried to answer these questions, I'll try to answer them myself. I'll note that I sent these questions to Radsone a week earlier but they didn't respond.
It seems the app is only for use when using a Bluetooth connection. When it is used as a direct USB DAC/amp, the device has no extra functionality beyond volume control. The device wants to default to a Bluetooth connection even if it is plugged in by USB. I've only been able to force it to a direct USB connection by turning off my phone's Bluetooth radio. I don't mind that the app doesn't function in this mode because the typical USB DAC/amp doesn't have an app or much additional functionality beyond volume control anyway.
I had been using Neutron and Player Pro and feeling satisfied with those. The best headphone I had been using was a Sennheiser HD650. Now I am using a Shure SRH-1840. I think these headphones are phenomenal - way better than the HD650 - and they are making the sound quality differences by interface type nakedly obvious. I can easily hear a very significant improvement when using the ES100 direct over USB. I listen mostly to classical music, and with this combination, a vast amount of texture and detail is revealed that was previously hidden. There is also more volume. USB Audio Player Pro supports a bit-perfect interface with a USB DAC/amp. When that is turned on, the app can't apply any effects because then it won't be "bit-perfect" any longer. HibyMusic plays with the exact same "perfect"-sounding quality but it isn't so clear about what it's doing. If they don't sound exactly the same, then one of them is not sending a bit-perfect data stream. Both sound far better than Neutron with 64-bit processing, or with any other type of processing that that app offers, in my experience so far.
When I plug in the ES100, I see a system dialogue that says "Allow USB Audio Player PRO to access EarStudio USB DAC?" with an option to always open the app when the ES100 is connected. You have to hit "cancel." It asks separately, "Open USB Audio Player PRO to handle EarStudio USB DAC?", also asking to always open. Cancel out of that, too. Do not turn on "Exclusive HQ USB audio access" if you are using HIbyMusic.
If you aren't sure if you are listening through a bit-perfect direct-over-USB connection, I suggest that you fiddle around until you can make it work for you. Once again, I'm really interested in any advice or insight that anyone else can offer.
post-14965187
Post #4,653 of 6,241
skeptical
Anyone knows what would be the best short 40cm mmcx balanced 2.5mm cable for es100 ?
post-14965354
Post #4,654 of 6,241
MariusAB
Lithuania
Lithuania
post-14965375
Post #4,655 of 6,241
Rowethren
I have mentioned it before but the cable I got from Forza Audio Works is pretty great. They can make it the exact size and termination that you want.
Reactions: capnjack
post-14965378
Post #4,656 of 6,241
capnjack
England
England
I’ve dealt with Forza a few times in the past and they are a really great company, just let them know what you need and they’ll sort it for you! :)
post-14965382
Post #4,657 of 6,241
Broquen
Barcelona, Catalonia
Age
46
Only problem are prices vs AE
post-14965411
Post #4,658 of 6,241
grininja
After 6 months my ES100 is dying...
Powered on it is shutting down abruptly at small moves. It restarts when pressing play but a little jiggle is enough to shuts down again. It doesn't matter the type of connection. It happens on bluetooth (doesn't matter if 2.5" and 3.5" output) and it happens also when connected as a USB DAC. I've updated to v2.0.2 firmware but nothing changed. It is a hardware failure because only a simple tap on it when it sits as a DAC on my desk is enough to cut down the power.
I really liked this little gem when it was working.
post-14965678
Post #4,659 of 6,241
Mouseman
USA
USA
You could always buy the short cable off Ali, and buy a set of the adapters to go from MMCX to 2-pin. I have a set, and they don't add that much length to the connections.
Reactions: MariusAB
post-14966022
Post #4,660 of 6,241
Crandall
USA
USA
Sounds like a bad solder joint between the battery and control board in there somewhere.
post-14966173
Post #4,661 of 6,241
ClieOS
IEM Reviewer Extraordinaire
Middle of Johor, Malaysia
Website
InEarMatters.net
post-14966198
Post #4,662 of 6,241
skeptical
post-14966255
Post #4,663 of 6,241
MariusAB
Lithuania
Lithuania
I've seen this one on amazon, someone made some pictures of weak broken connectors, also I need them to be straight for my iems and those are angled. Do you know what's the difference between 8 stranded and 4 stranded sound wise?
In theory 8 stranded should be better then 4. But differences couldn't be big with iem cable. But still beter preservation of original signal with 8 stranded, bass control better, better separation. But it is small differences so if it will be noticable depend on the transparency and level of your iem.
post-14966270
Post #4,664 of 6,241
Broquen
Age
46
This is taking into account same materials and construction quality. In fact, if I'm not wrong, it is more expensive to manufacture a cable with more strands, so price can be a clue too.
Lately litz cables have been mentioned, which are supposed to avoid the multi strand issue of signal jumping from one conductor to another.
post-14966401
Post #4,665 of 6,241
skeptical
Shameless plug - check out my sig.
Your hands grow from the right place, that's for sure. Since you're doing everything by yourself, Why wouldn't you pick up a black color cable, connectors and some angled jack? Do you know how to map correctly 4-8 strands balanced cable to unbalanced iems ? I have some fixed wired jvc fx 750 which I'd like to turn into balanced 2.5 with 8 strands black cable, preferably with removable connectors. I can't find this info anywhere.
Users Who Are Viewing This Thread (Users: 0, Guests: 5)
