Radsone EarStudio ES100
Discussion in 'Portable Headphone Amps' started by m4rkw, Dec 12, 2017.
298 299 300 301 302 303 304 305 306 307
309 310 311 312 313 314 315 316 317 318
  1. ClieOS Contributor
    Yes, it is possible.
    Detail answer can be found > start the EarStudio app, click on top left corner > Manual > UK (open pdf) > score down to [Equalizer Tab] :stuck_out_tongue_winking_eye:
    Roll likes this.
  2. arbiter76
    I have not had any serious issues. Methinks there might've been a ram problem but Android has handled that fairly well the last 2 or 3 iterations. Otoh, I think there is a higher probability it could've been an app cache issue. I have not had cache issues for a long time but find your app info, clear cache, uninstall app to be thorough and reinstall and setup. That has cleared issues for me several times. I have only had to factory reset phones after rom installs and had app backups so no biggie.
  3. Jearly410
    I’m using an iPhone XR, but if/when the problem happens again I’ll do a complete uninstall/reinstall of the data.
    Another thing that’s been happening is the es100 reboots itself when a 2.5mm cable is plugged in. I’ll have music playing and move the cable/es100 which causes a reboot of the es100. Anyone else?
  4. niron
    Never had this reboot problem whatsoever. And I'm using a 2.5mm cable plugged into my ES100 all the time.
  5. arbiter76
    I have no idea about iOS if there are issues. I would try reinstalling firmware and seeing what is stable for you.
  6. tracyca
    I purchased this little gem last night from Amazon for 70 usd new and received it today, I was never a believer of Bluetooth. I was wrong this is a great little device!
    Roll, Lurk650, Marco Angel and 5 others like this.
  7. Lurk650
    BT has made great strides in the past couple years. I also have the new Advanced Sound Model X and they sound awesome for being completely wireless. I had tried some Sound Peats a year or two ago and they were not good at all IMO
  8. LTDJ
    Looks like Amazon UK stopped selling them directly and all 3rd party sellers want twice as much. Is this thing getting replaced/discontinued?
  9. Matvei
    I'm using USB audio player pro.
    What should I set the sampling rate to, device native, fixed 44.1 or variable?
    I'm using ldac. I don't understand how android processes audio when sending over bluetooth. My device native sample rate is 48
  10. ClieOS Contributor
    That setting should only affect built-in DAC on your smartphone and have no effect on your ES100. Keep it to native.
  11. Matvei
    Clearly that isn't the case.
    If you select native, then 24/96 files are down sampled to 48 BEFORE being passed to the OS. What happens after that is anyone's guess, I don't know if it then resamples to 96khz for ldac before bluetooth output?
    If you select variable it will send unaltered 96khz to the OS, but normally android will then down sample to 48khz using an algorithm that's inferior to UAPP. Does it still do this when outputting over bluetooth?
  12. ClieOS Contributor
    According to UAPP developer, variable setting will not resample the files unless they are over 192kHz. So if you suspect Android will resample your music with an inferior 48kHz SRC and rather prefer UAPP to do the job, then you want to set it to native (which UAPP will resample everything to 48kHz (most Android default) first, before sending to Android, thus saving the files being resampled again by Android. But if you suspect Android doesn't resample, then you can keep the file intact with the variable setting. The point is, I know some Android smartphone makers (and some higher end Android DAP makers as well) use their own audio driver and not the standard Android driver, so it is hard to say for sure whether SRC will happen or not.
    pitsel likes this.
  13. Matvei
    My phone resamples everything to 48. My question is how does bluetooth output affect this, or does it go through the same stack?
  14. Omoshai
    i hope radstone is working on a new version which uses type c and supports 4.4mm headphones....
    Marco Angel likes this.
  15. benoe
    I hope Radsone is not giving up on ES100 and will release more firmware updates.
    bidn and Marco Angel like this.
