Radsone EarStudio ES100
post-14924195
Post #4,516 of 6,245
Ocelitgol
Previously known as stormers
NYC
NYC
Samsung S10 owners: Playing LDAC best quality (909/990 kbs) usually results in choppy sound.
To resolve that issue, disable the LOCATION icon on the Settings pull down menu.
Hope Samsung will rectify that issue, soon.
saw that on another forum
It doesn't work for me on s8+, probably just S10?
Also, is there anyway to make the settings stick? When I change the LDAC Mode, turning off the module and reconnecting it, it returns to best effort :frowning2:
post-14924248
Post #4,517 of 6,245
zolom
Here
Here
Here also, LDAC state has to be set again. Default mode is 'best effort'.
post-14924261
Post #4,518 of 6,245
Cevisi
Germany
Germany
I tried it today whwn i set to 909kbs i get the same problem just set it on best avaliable
post-14924562
Post #4,519 of 6,245
Ckro
EU
EU
Have some issues on my side with Huawei P20 pro with ldac, so I stay in aptx hd and I'm not sure I could tell the difference...
post-14924907
Post #4,520 of 6,245
skeptical
Bought the ES100 from Amazon a couple of weeks ago, love this tiny thing!
Much much better than shanling M0 and co.
Love the app also, a very nice feature with the eq.
Interesting, I was debating between these two. Shanling M0 has some advantages over es100. It can work additionally as a transmitter plus independent DAP,so you can go totally wireless. I don't remember why I decided to go with es100. How es100 is better?
post-14924913
Post #4,521 of 6,245
Cerebro
Europe
Europe
It is quite rigid so it protects its contents very well at the expense of not being expandable. I'm not sure about the size of your iems but i have to take some time to sort out the contents when packing everything in before zipping it up so it's not something you can stuff things in without giving it some thought. Sounds like a hassle but i got used to it in time. And the whole size of it if everything fits in is like the size of a smartphone so it's pocket friendly. My only conern is the micro usb charging cable of the charging pouch is quite short and i wished it was a right angle one instead of a straight jack so extra care is needed when in use. Oh yeah I'm using 40cm cables with my iems so i think a standard 1.2m cable is asking too much of it. My advice is if there is a retail store around you, go and see if everything fits before buying. Hope this helps!
Thanks, that helps! Unfortunately I think I have to pass on it for now, if only they sold a version that’s a little bigger... it seemed to be the perfect solution. I’ll be using it with a cable that’s 1.2m (maybe later I’ll switch to a shorter version depending on how I end up using the es100) and one of a few different iems (Hifiboy OSV3, ZSN pro, ****)
Does anyone else have a nice way to package the es100, one set of iems and a cable (maybe some extra eartips)?
post-14925009
Post #4,522 of 6,245
Ckro
EU
EU
I found the M0 quite boring in fact. I prefer my smartphone output with Dolby Atmos over the M0...
With the Radsone, I definitely got an improvement: better staging, deeper bass, definitely more power, and even a 2.5 output.
And I can navigate with my smartphone, much better than M0 screen.
Reactions: Cevisi
post-14925046
Post #4,523 of 6,245
skeptical
That is how i deal with mine. You can fit in there 1.2 m cable like i did plus some extra tips. There is no much extra wait, sometimes i carry them around hanging with everything in pouch together.
I'm sorry for duplicates, I'm posting here pics first time.
20190428_135751.jpg 20190428_135751.jpg 20190428_135857.jpg 20190428_140850.jpg 20190428_135644.jpg 20190428_135913.jpg 20190428_135751.jpg 20190428_135751.jpg 20190428_135857.jpg 20190428_140850.jpg 20190428_135644.jpg 20190428_135913.jpg 20190428_135857.jpg 20190428_140850.jpg 20190428_135644.jpg 20190428_135913.jpg 20190428_143131.jpg
post-14925066
Post #4,524 of 6,245
Pricklyears101
Singapore
Singapore
Nice woodies btw
post-14925098
Post #4,525 of 6,245
skeptical
Nice woodies btw
Thanks. I picked them mostly because of their form factor and efficiency. These must be the loudest 16 om iem i ever came across but they don't deliver sufficient subbass for me which I crave for. I'm in the market for new iem's with detachable cables to try on that balanced output but they have to be small footprint and efficient with lot of subbass and clarity. Mission impossible to find some at reasonable price.
post-14925101
Post #4,526 of 6,245
Pricklyears101
Singapore
Singapore
Easy. Mdr-ex800st with tape mod. There's an extensive thread about it on headfi.
Reactions: redrol
post-14925115
Post #4,527 of 6,245
skeptical
I'm following that thread. They are the best contender so far except they really will shine with lots of power and they got a proprietary cable which is hard to find a short balanced one to replace with.
post-14925141
Post #4,528 of 6,245
skeptical
The classic, Jack of all trades and master of none. Thanks body, I new i did choose the right one but M0 still was lingering in my mind, not any more.
Reactions: Cevisi
post-14926255
Post #4,529 of 6,245
Cerebro
Europe
Europe
Thanks for posting. I was thinking of something like these for protection when I’m not using them:
https://s.click.aliexpress.com/e/cdkdks8u
https://s.click.aliexpress.com/e/cMYf5HYU
https://s.click.aliexpress.com/e/cG06GMks
But I’m not sure which will fit.
post-14926759
Post #4,530 of 6,245
skeptical
Reactions: Cerebro
Users Who Are Viewing This Thread (Users: 0, Guests: 5)
