Radsone EarStudio ES100
Discussion in 'Portable Headphone Amps' started by m4rkw, Dec 12, 2017.
276 277 278 279 280 281 282 283 284 285
287 288 289 290 291 292 293 294 295 296
  1. skeptical
    +1 For me it's enough just to shortly plug it in for charge.
  2. skeptical
    You're lucky, the new once get shipped with F/w 2.0.2 pre installed. what's your real world battery live?
  3. MisterMudd
    After 8 months of ownership I'm still getting 9+ hours. Got 12-13 when it was new. Use it all day about 2-3 times a week. Mostly with easy to drive ear buds. Vido sounds great with the ES100.
    scotvl and pitsel like this.
  4. waynes world
    I held off on upgrading the firmware for a while, but I've been on version 2 for a couple of months now. I don't know exactly how long the battery lasts for me (ldac, also after approx 8 months of ownership), but it's probably over 8 hours. No problems for me at all.
  5. shrimants
    for real, how are we supposed to get warranty/RMA support? My clip broke (metal hinge pin sheared on one side), it makes the ES100 quite useless to me. I've sent emails via the app, sent email via their contact form, and sent a facebook message and not a single reply from the company.
    At this rate id rather cut my losses and go to Fiio.
  6. waynes world
    How does Fiio handle it if you break the clip?
    Btw, I'm not defending not getting any response back. When did you send your correspondence?
  7. shrimants
    Fiio's support sends an automated reply to confirm receiving the mail. then generally someone reaches out within 24-48 business hours. Dunno how their actual RMA process goes, never had to RMA somethign specifically but I've utilized their support before, it is phenomenal. They are also extremely active on both their facebook pages and their own forums.
    I do want to mention, it turns out my clip didnt "break" per se. There are 2 metal caps on the sides holding the hinge in place. one of those caps apparently had the glue fail, so the hinge slowly creeped out and got undone from the other (still capped) side. I found a safety pin and pushed the hinge back in place. The cap on the other side "oozed" off, the glue on that was degraded as well. I then used super glue to sort of spackle over where the caps were, so hopefully once thats dry it should hold in place pretty well.
    I still have my first gen fiio X3 that ive been using as a dac and it hasnt missed a beat yet, and i bought that thing AGES ago, so no idea how fiio's specific RMA process works. Sort of hard to damage something or have components fail when you're encased in a solid metal chassis lol
  8. Lurk650
    FiiO is a huge company...Radsone not so much
  9. Devodonaldson
    Had the same exact issue and applied the same fix to my es100 about 2 months ago. It unfortunately ended up in washing machine. Didn't want to just buy another one so I purchased btr3 to try it. I was very surprised. Absolutely less power, but for iem and 50ohm and less headphones, I actually like sound of the Fiio more, so I kept it. ES100 is amazing, but I rarely if ever used the eq, and wanted to try competitor since I HAD to replace
  10. RobinFood
    Is it possible to download older firmware? What is the best firmware?
  11. maniac2003
    @RobinFood
    Only the latest firmware is offered by Radsone. Maybe someone here can upload the firmware you want.
    I'm on the latest firmware, which works fine for me.
  12. HiFlight
    Please keep in mind that if you are on v2.0 or later, installing a version earlier than 2.0 will brick your ES100.
    pitsel likes this.
  13. JoshG1217
    Hey guys,
    Curious if anyone has used a similar adapter that also includes ANC. Since ANC is just microphone and software dependent (as I understand it), seems it could be added to Es100 with a firmware update, like Nuraphone did. Love my Amiron Wireless, and the ANC of Sony and was thinking about an AnC version of Es100 to use with my DT 1770. Works with the es100 already, but I've gotten so used to sony's ANC that even try nominal noise from using the DT 1770 in the gym really bothers me. Alternatively, if someone wants to put the Amiron Wireless driver in the Sony XM3 for me and then migrate it into a V Moda Crossfades 2 housing, that's even better! :wink:
    Thx
  14. rkw
    For ANC to work properly, microphones need to be positioned at each ear.
    Toastybob likes this.
  15. JoshG1217
    Oh, got it.
