Is there a possibility that my ES100 significantly deplets my phone battery while connected idle to bluetooth, without playing anything?
It won't deplete battery anymore than a standard BT headset, no. But there may be a process running in the background you're not aware of. Have you tried the usual - ES100 restart, phone restart?Is there a possibility that my ES100 significantly deplets my phone battery while connected idle to bluetooth, without playing anything?
Dude, when I read your comment my first thought was, come on, there's a $500 detail monster with ten times the weight and size versus an ultra-portable $100 device capable of the best BT possible transmission. It's not a knock on the ES100 to admit it's below the Mojo at what the Mojo does best. So I just went through the same playlist I used to audition the Mojo a few days ago. I still think the Mojo is a step above - fuller, with a better handle on explosive dynamics, more detail. The ES100 sounds softer, probably by design, even a tad veiled by comparison. But it's a closer race than I envisioned in my mind. The Radsone is one of those devices that has you doubting the worth of any upgrade. Is such-and-such really worth 5x, 10x more to me? Can I justify the footprint on my desk? Is it truly more enjoyable? It's a rare device that will have me say yes. For instance I listened to the Astell&Kern Acro L1000, a 1000€ device. Apart from its ability to drive desktop speakers, there is literally nothing it does better than the Earstudio - and quite a few things it does worse.Es100 sounds better and more detailed than Mojo so strike that out
Lol I restarted my phone and the whole time the song was still playing. That is not normal at all. The phone was off and music was still coming through.Well does the song still plays after you pulled your sd card?
If it did then you might have a problem…
Apparently, you had the second device connected to ES100 which was playing it. Happens.Lol I restarted my phone and the whole time the song was still playing. That is not normal at all. The phone was off and music was still coming through.
There is no second device lol. I only have my phone connected to the ES100. Nice guess though.Apparently, you had the second device connected to ES100 which was playing it. Happens.
Looks like I'll have to go listen to the Mojo again
Sharp is only reasonable option.
I agree with this. Have been using slow roll-off up until one or two weeks ago. Sharp is my favorite but as zerolight said; sometimes it gets shouty.I've been flip flopping between sharp, slow and delay sharp since I got this. Depending on the track they all have advantages. Most of the time I like sharp, but sometimes it gets shouty or spikey.
Setup EQ to what your ear likes. Keep filter sharp. Other filters make aliasing and skew FR.Sharp is the only reasonable option? LMAO. Go with what your ear your likes not what people tell you is better, Zero.
Balanced is technically better from all perspectives - FR, crosstalk, emi and ground noise cancelling. But you might not pass blind test to hear a difference except higher volume.Cheers. Revisiting Sharp today. Any benefit to going balanced with my K10s?
Hey, I'm new to this thread. I love my ES 100 great device.
I have a suggestion for a feature: it would be amazing if Radsone could implement a slider that controls the analog volume in the status bar of android. I've seen this been done by other apps before. That way one could alter analog volume without going into the actual app it self nor fiddling around with the tiny volume control buttons on the unit. It would even be possible to change analog volume from Android's lockscreen as one can pull down the status bar without unlocking the phone.
Don't know if something similar could be done on IOS but for Android it would certainly help usability.
Thanks anyway for the awesome device
