J The Killer
How would the dual AK4375A DAC of ES100 compete with single AK4376A DAC of Fiio BTR3?
Also, BTR3 is expected to be $30 cheaper than ES100..
Try the VEClan website in the basic cable section, you should find a choice or 2 there.Check product spec sheet, there will likely be little to no difference except some pin layout or form factor stuff.
Also for cables I went with noble audio. They ship from US which was important to me, and they are incredibly well built. Bought one balanced and one mic remote cable. Wasn't sure if I'd be going wired or wireless. Only down side is no customizable length. I'd love a 1 or 2 foot balanced cable.
Triton Audio Cables, he is a member on here. @alpha421Check product spec sheet, there will likely be little to no difference except some pin layout or form factor stuff.
Some cheaper cables tend to yellow or they fall apart. I have a few solid ones that are cheap. Then there is the other issue of if there is a problem and its a cable you spent a bit of money on how can you get it repaired, that's why I like David @ Triton. He has been solid at customer service and getting things repaired as needed. Turn around is no more than 7 days. I would never spend over $200 on a cable because indeed it is just wire, but I'm willing to pay ~$100 for a solid quality cable.its just freaking wire.
i tried finding DIY parts but just for the 2-pin 0.78mm connectors it was practically impossible to find. when i did find it, it was 10 bucks for that part alone. very unfortunate, as im fully capable of building a very nice cable but have pretty much no access to reasonably priced parts.Connectors quality, wire resistance and look - that's all that matters. Cost of good gold plated connectors for retail volumes is few bucks. Cable another few. Anyone charging 100$ for a headphone cable is making above 1000% profit or he is an idiot. Yeah and there are weird wires that do nothing useful, look ugly and can cost anything.
Why nobody asking total cable resistance? It's actually important below 15Ohm impedance headphones.
Aliexpress?i tried finding DIY parts but just for the 2-pin 0.78mm connectors it was practically impossible to find. when i did find it, it was 10 bucks for that part alone. very unfortunate, as im fully capable of building a very nice cable but have pretty much no access to reasonably priced parts.
also, fwiw, i have yet to find a single mic/remote module that i can DIY with.
You can get a set of them on aliexpress for a few bucks. That’s where I buy my 2pin connectors... last I paid was I think $12 for four pairsi tried finding DIY parts but just for the 2-pin 0.78mm connectors it was practically impossible to find. when i did find it, it was 10 bucks for that part alone. very unfortunate, as im fully capable of building a very nice cable but have pretty much no access to reasonably priced parts.
i wasnt finding any that seemed terribly well built or pretty. also i nixed the idea because i didnt want to buy a giant spool of wire just to build 1 or 2 cables lol.
if i do find a mic/remote module thats DIY friendly i'll totally give it a shot though.
