Raal Ribbon Headphones - SRH1A
post-15549151
Post #2,071 of 2,264
Jon L
For him, f/1.2 is a prime number
Phone end is 3.5mmTRRS - tip and ring1 is positive, ring2 and sleeve(3) are negative.
Amp end is XLR 4pin female - pin 1 = R positive / pin 2 = R negative / pin 3 = L positive / pin 4 = L negative
This actually turned out to be incorrect.
Facing Amp's XLR 4 pin female jack, pin 1=L positive, pin 2=L negative, pin 3=R negative, pin 4=R positive!
Reactions: Thenewguy007
post-15549154
Post #2,072 of 2,264
Jon L
Now that I have the 4-pin female XLR adapter, what would happen if I hooked up my other headphones to Jot R? (Baffle Step turned off of course)
post-15549448
Post #2,073 of 2,264
astrostar59
Member of the Trade: Aries Cerat Espana, Auriculares High-End
Somewhere v hot
Somewhere v hot
Please don’t. I just settled down with my Abyss. Head-fi is a mistake. I need to quarantine myself from it!
Worry not my friend, IMO the Abyss still beats the RAAL. I am now ducking, hard hat fitted.....:darthsmile::darthsmile::darthsmile:
post-15550016
Post #2,074 of 2,264
BrowChan
United States
United States
Haha, I still need to get a good AMP for my TC. Price goes up. RAAL with JR (about the same price as TC) gave better resolution than my TC with the AMP I have but I need to compare them for a while to trusty know as I only auditioned the SR1a for a bit.
post-15550095
Post #2,075 of 2,264
565hunter
San Diego, CA
San Diego, CA
Jon, my pin out is of the cable supplied by RAAL. On the XLR (F) side it is using the numbers stamped into the plug. My post was/is correct for this cable. I verified that the Right/Left channels are correct in the sound field. Are we measuring the same thing?
post-15550666
Post #2,076 of 2,264
Jon L
OK, I was looking at the 4-pin male jack on amp's face and got backward. I placed the correct diagram above.
I went back and triple checked the Raal stock cable pinout (4 pin female), and is it possible something changed in Raal between your Raal and mine? Because my Raal stock cable's 4-pin female pinout is still different from yours. Mine is pin3=L negative, pin4=L positive, which is reversed on yours. (Right pins are same).
post-15550778
Post #2,077 of 2,264
terirapt
I just got the SR1a and the Jotunheim R.
Am using the SP2000 as the source; lineout at 2v. With the Jotunheim R volume knob at about 12 o’clock and above (which to me is not particular loud actually), I tend to get crackling distortion noise on SR1a on quite a number of tracks, I listen mostly to classical and jazz. The crackling does go away when I reduce the volume but sound is too soft. The SR1a is at 45 degree out.
Also the volume does not change much on the SR1a with the Jotunheim R knob between 12-5 o’clock.
Any advise what may be the issue and how can I resolve the crackling?
Sorry for asking; I have searched for distortion/crackle in this forum; found a number of posts but still not clear what the solutions may be. Thank you for the advises.
post-15550793
Post #2,078 of 2,264
565hunter
San Diego, CA
San Diego, CA
Jon, I just got off the phone with Danny at RAAL-requisite to determine which of our cables is correct. Yours is correct. I was sent a defective cable. He is sending out a replacement this afternoon. Listening for phase had not been on my list of tests for these but as I do it now, I clearly hear that they are not in phase. He also mentioned that they have made a change in the stock cable because it had been reported that there was channel imbalance in some of the cables that have been sent out due to manufacturing differences in the individual wires used in their original cables. The original cable had multi colored individual wires from different spools. According to Danny, irregularities in the individual wires accounted for up to 1.5 dB difference between the channels. They are now using wire from the same spool, one contiguous length of wire for each cable to negate possible irregularities. He will send a replacement cable to anyone who requests it. Send an email to danny@raalrequisite.com for more information. I'm really looking forward to hearing these properly for the first time... -Tom
post-15550820
Post #2,079 of 2,264
Jon L
Are you EQ'ing the sound somewhere else? EQ'ing the bass up will use up a lot more of Jot R's power. In addition, if you are using digital EQ, don't forget to normalize the entire EQ curve down to prevent digital clipping, which can give you crackling noise.
If not EQ'ing, fanning out the SR1a 45 degrees may be requiring too much power, especially if the music tracks are recorded quieter, e.g. classical (actually a good thing for extended dynamic range).
I actually do not enjoy SR1a's sonic signature with them fanned out that much and usually keep them less than about 15 degrees out, same thing I did with AKG K1000's.
post-15551165
Post #2,080 of 2,264
dieslemat
Singapore
Singapore
Can you name some of those tracks? I suspect something also but maybe only coming from the Jotunheim R (production).
post-15551193
Post #2,081 of 2,264
Ciggavelli
Houston
Houston
I had the same problem. Turns out my preamp was causing it, by having the volume on it too high. Maybe your DAP’s volume needs to be turned down, then you can turn up the JoTR higher without crackling
post-15551236
Post #2,082 of 2,264
terirapt
Just a few examples but I get crackling for many more other tracks :
- Beethoven Piano Concerto No 5, Boston Symphonly Orchestra, Seiji Ozawa, Telarc : very bad starting from the 1st note.
- Holst Planets, Sir Adrian Boult, London Phiharmonic Orchestra, EMI : occasionally
- Karajan Gold, (Deutsch Gramophone) track 3 Violin Concerto in D major Op 61 Rondo, Deutsch Gramophon : bad when the orchestra plays
- Live at the village vanguard, Track Sand Dune, Christian McBride Trio : seems to crackle with the piano.
Thank you.
post-15551241
Post #2,083 of 2,264
terirapt
Thank you for the advise. Yes, I do observe that the crackling stops when I turn down the volume of the DAP. However, the volume sounds quite low; probably my hearing is bad :). I then had to turn up the volume knob of the Jotunheim R but I realise the volume does not actually increase anymore after 12 o’clock even if I turn up all the way to the max at 5 o’clock. So 12 o’clock then crackling still but a lot more infrequent compared with my DAP volume turned up.
post-15551259
Post #2,084 of 2,264
Ciggavelli
Houston
Houston
That is very odd. I can go further than 12o’clock and the volume increases. I have never gone above like 2 o’clock though previously, and it is very loud.
I keep my preamp at like 9 or 10 o’clock, any higher and I get bass clipping.
I think you may have a defective unit. I just increased my volume on the JotR Gradually past 12 o’clock, and it got louder and louder. At 3o’clock it was unbearably loud.
post-15551991
Post #2,085 of 2,264
Thenewguy007
Can you try connecting it to something else other than the DAP to see if that might be causing the anomaly? Can you hook the Jot directly to your PC?
