TheMiddleSky
3-Way Amplifier Comparison. Gear use: Raal 1995 Immanis (32 Ohm Interface), Rockna Wavedream Signature, connection through RCA Cable.
- Cayin 170HA use Triode and Dynamic Mode, with Mid Impedance Out, standard tube.
- Feliks Envy Performance use the highest gain setting, standard tube (Full Music + PSVane)
- Riviera use Low Impedance Out (Mullard NOS)
"TLDR" Not in particular order:
Riviera AIC-10: Master of Technicalities
Feliks Envy Performance: Master of Midrange
Cayin Soul 170HA: Master of Soundstage
To give more detail about my impression:
Riviera clearly excel in term of resolution, effortlessly provide the smallest micro detail and transparency feeling, with better layering/separation than the other 2 tube amps. At the same time, Riviera also become the punchiest amp as well. Percussion notes hit really hard, it creates rock solid feeling. Sparkle treble is in between Cayin and Feliks with bite Upper Mid and Midrange become the most energetic among all of amps here.
Feliks Envy Performance has more midrange presence than the other 2 amps, with more gentle and rounded high notes, make overall presentation become "classic" tube notes with warmth and "wet" feeling, but uniquely still provide solid attack notes for percussion and bass. While Riviera does wider soundstage, but Envy feel slight more "surround" to project depth soundstage, with a little bit better height. Last minute detail seems a bit blurry compared to Riviera, but character wise, Envy also produce more rounded notes.
Cayin Soul 170HA definitely perform the most spacious soundstage in all direction. Just a little bit wider than Riviera, but has more apparent advantage at depth and height. Attack notes from treble/midrange/bass are the softest here, and midrange area somehow also feel the least "meat on the bones". Lots of airy feeling on top, but bass bass still feel heft, full body and tight. There's a constant of sweet tube character through all spectrum, like instrument decay lingering around in really natural way before disappear.
All in all, I can vouch these 3 amps perform excellent for Immanis. It's back to the subjective listener taste and set up to decide which amp is the best. As these 3 amps rather transparent with set up, synergy of the whole chain really play big roles here.
P.s: My personal preference is Feliks Envy Performance. While all spectrum of frequencies are important, but Midrange area is one aspect that I truly enjoy the most to convey emotion feeling from singer. I can easily understand if others may pick different amps here, especially as they are truly excellent as well!
