energie
- Sep 19, 2008
are we close to the best possible drivers? :|
Originally Posted by Sovkiller /img/forum/go_quote.gif We do not need more drivers, we need better drivers, still going only to 18KHz, so I'm assuming the same performance on the high freq as we have now... |
Originally Posted by ljcii /img/forum/go_quote.gif Maybe the ultimate one wil be a 6 driver one to make the range hit 20khz... |
Originally Posted by Maxvla /img/forum/go_quote.gif Is that supposed to be 68 ohms on a portable device? Yikes, talk about required portable amp. Isolation is rather poor (24db) for a custom also. Sensitivity is very high also, you will certainly bring out any hiss the player will have. |
Originally Posted by qusp /img/forum/go_quote.gif can you hear over 18khz with any accuracy? I cant; I would say only a handful of teenagers could. I agree totally about the need for better drivers rather than more but that doesn't necessarily mean taking the dynamic range higher. 20hz is a bit slack though. good point about the SMD crossovers though Stikk; 2 is enough; 3 quality drivers with well picked crossover points should be enough for any IEM. |
Originally Posted by boomy3555 /img/forum/go_quote.gif Has anyone heard these ? E.A.R Z5 Monitors Frequency Range: 20Hz-18KHz* Nominal Impedance at 1KHz: 68Hz* Sensitivity at 1KHz: 155dB* Noise Isolation: 24dB +/- 2dB Input Connection: 1/8" (3.5mm) Gold Plated Jack Costs: $1000.00/set The Z5 is the ultimate in music monitor systems. It incorporates a balanced dual armature driver for your low end frequencies, a single mid driver and a dual tweeter driver to handle the high frequency tones. There are an additional two crossovers on the dual drivers that makes this unique design a definite studio quality performance and surround sound feeling monitor system. This info is pulled Directly form their site so I appologize in advance for any copyright infr. I didn't want to mis-quote |
Originally Posted by GN85 /img/forum/go_quote.gif ...... link? |
Originally Posted by Punnisher /img/forum/go_quote.gif Actually I'm sure these would sound great out of a portable player. Also they probably won't hiss. IEM manufacturers really need to make their phones impedance higher. |
Originally Posted by Punnisher /img/forum/go_quote.gif I'd take hiss free operation in exchange for lower battery life any day. Hearing hiss out of iems is unacceptable, imho. |
Originally Posted by Sovkiller /img/forum/go_quote.gif I certainly do (measured by an audiologist)... The main problem is not if we can or not ear that high but consider that the stated freq is the limit for them, but maybe the actual roll off will begin far before that, if they rated 16, maybe they can not even achieve 14 or 12 at full extension, and those are indeed inside the old man audible spectrum... Probably there is not too much musical info at that freq, same as lowers, but some harmonics or whatever, that maybe is what gives you the natural sound, in reality the real musical freq spectrum is far above 20KHz for mainly all instruments...I do not know for sure what is, but the fact is that none of them sounded right to me, the high freq sounds fake and unnatural, and maybe is due to another reason and I'm blaming the cut of the freq for that, I do not know for sure, but the coincidence is that all of them are alike regarding the way they sounded, and all of them cut the freq the same way around the same figures... |
