Quick Impression: Sony MDR-7550
post-12802222
Post #631 of 643
fade2blak
For anyone looking for less priced custom cable,
http://store.treoo.com/nocturnal-audio-calyx-4-conductor-copper-custom-cable.html
post-12917297
Post #632 of 643
twiceboss
Can i know whether this iem is fatiguing? In terms of highs. I have sensitive ears but would love to have punchy bass and details at the same time for iem.
post-12917784
Post #633 of 643
Conext
I certainly would never characterize them as fatiguing.
Reactions: Sp12er3
post-13079796
Post #634 of 643
esm87
Anybody using the ex800st with the vent mod?? Thoughts please
post-13090069
Post #635 of 643
kms108
Just Got these today for my Sony.
OK the cables don't look right, they are off my XBA 300, just trying them on.
Reactions: Sp12er3
post-13393384
Post #637 of 643
hiholto
Yes please! Where on earth did you get these? Please share. This would change my world right now as I have the Shure 846s and the Z5s as well as the 7550s and would love to be able to swap cables!
Reactions: Sp12er3
post-14854511
Post #638 of 643
waytoodeep03
So with the tape mod do i just completely cover it up with tape or do i still poke a hole in it?
What does the hole do
post-14876651
post-14878023
Post #640 of 643
SoLame
El Rancho PR, LA-CA
El Rancho PR, LA-CA
I just wanted to share "my" experience and, of course, YMMV.
I once owned all three IEMs you mentioned at the same time and I also thought about the ease of swapping cables among them. So I sourced a pair of adapters.
Turned out, I didn't like them much.
Even thought the adapters are well made and they fit in my MDR7550 neatly, I found that it's not so easy to disconnect cables. It's super tight. I was afraid that I would break either the adapters or cable connectors every time I attempted removing cables.
More importantly, the adapters change the angle of cable which makes it kind of awkward to wear MDR7550 over ears.
:beerchug:
Reactions: Sp12er3 and mochill
post-14899915
Post #641 of 643
Pricklyears101
Singapore
Singapore
I've been thinking about this issue as well. There are angled mmcx connectors like those used in the Fiio line.
Reactions: Sp12er3
post-15147354
Post #642 of 643
Sp12er3
Asia
Asia
Website
randomnessdotco.wordpress.com
I've been so endlessly intrigued by the 7550 that I've finally decided to just order a pair to compare to the EX1000.
Going by both Tyll's graph and Sonove's, it should be possible to equalise an EX1000 to sound quite similar to the 7550 / EX800 by reducing some of the frequencies above 2k. I really wonder if the actual in-ear experience of the EX800 will sound like such an equalisation. I tried an EQ of -1db at 2k, -3db at 4k, -5db at 8k, -3db at 16k. So far it sounds like a smoother EX1000 with a slightly more closed in soundstage because the lingering 'ambient' notes in the high frequencies are diminished.
Was anyone ever able to confirm whether the 7550 (Multi layer polymer) actually uses a different driver from the EX1000 (liquid crystal polymer)? While the frequency response graphs are pretty darn similar (the use of a filter on the 7550 seemingly being responsible for most of the changes) Tyll's THD graph for the EX1000 is noticeably better than the one for the 7550, especially as the EX1000 doesn't have much of a rise in distortion at 100db.
Then again, Sony lists a 500mW power handling figure for the 7550 vs 200mW for the EX1000...
I tend to think that the EX1000 has a bit more of a magic sparkle to it that makes it a better choice for a lot of tracks, but on enough tracks the treble sibilance takes me out of the whole experience.
The 7550 is a little more conservative / boring. It's amazing how much difference 3db or so can make across the treble range in taking out that sense of 'air'. However the sound is still emotive and beautifully mellow in its own way, and across all the music I listen to its more of a 'safe pair of hands'. I can listen for a long time with great enjoyment, and I really do value that (if for the protection of my ears alone).
It's definitely a compromise between the two. The EX1000 is the flashy one that would probably impress more on first listen, but the 7550 holds its own charm over the long run to me. The longer cable on the 7550 also makes it great for desktop use!
Thanks for the EQ note, will try em.
I'm most worried about that aspect for an adapter as well.. Sony's cable always have that bent build in into it.
post-15148030
Post #643 of 643
kms108
those are the old chinese adapter,the new one I have made in Japan has the slight bend.
http://e4ua.jp/?p=2825
Reactions: Sp12er3
