Quick IEM cable replacement
Apr 26, 2015 at 6:02 PM Thread Starter Post #1 of 3
bahaja
Jakarta
Hello guys,
Im looking to replace my JH5 cable as the right earpiece sometimes like to die on its own and i have to twist the cable to make it work.
Do you have any recommendation which cable should i get ? Fast delivery is the most important thing and sound improvement is next. Here in the UK, the JH5 replacement costs around 35GBP, and i'm willing to spend up till 100GBP if there is any significant sound improvement. I use my JH5 mostly for playing CS:GO than listening to music, so maybe something that can give a bit of sound separation might be nice. Are there any better cables compared to the stock ones within this price range ?
Apr 27, 2015 at 11:22 AM Post #2 of 3
entah
I don't know where the Fiio retailers in UK located, but you may find Fiio replacement cable for westone/JH
Btw, I found the turbulent labs has their custom IEM cables on sale http://turbulentlabs.com/up-occ-iem-cables/
Apr 28, 2015 at 2:55 PM Post #3 of 3
bahaja
Jakarta
I think fiio doesnt sell any replacement for JH here, i found UE replacement at amazon but no JH.
Thanks for the advice on turbulent labs, seems quite reasonable price for a spc
What about UK/EU based cable maker ? Do you have anything in mind that are good ? Theres toxic cable but its too bad that there is a waitlist of 6 months :frowning2:
