Attempting my first true do it yourself item beyond cables and a casing. I am making a very simple 2 in one out rca audio switch in a little altoids tin. I wanted to make sure I did the grounding properly as I don't want to blow anything up (if that is even a worry). I have read about attaching all the grounds together, but then what? Solder to the tin? Or could each jack be grounded by soldering the ground tab to the tin or removing the plastic washer and having the metal washer touch the tin directly? Thanks!
Edit: I am using a micro mini dpdt toggle switch from radio shack if that matters.
