Looking forward to your unvarnished review! Do you have something to bust hiss, should you need it?My QP2R should be in my hands by Wednesday, looking forward to it.
Questyle QP2R
- Thread starter unknownguardian
You warned me man, and I had both of ifimatch in my cart at Amazon but I figured I would wait and see how well my IEMs and QP2R get along.Looking forward to your unvarnished review! Do you have something to bust hiss, should you need it?
I think I probably need the 2.5 mm only anyway what do you think?
2.5mm does it for me, but the 3.5mm hisses less, and has less power so the capability to suppress hiss without clipping will be greater on the 3.5mm. if I use the Ultra setting with the Noble Encore, I get clipping.You warned me man, and I had both of ifimatch in my cart at Amazon but I figured I would wait and see how well my IEMs and QP2R get along.
headwhacker
- Sep 4, 2013
The hissing is only audible if you have a sensitive iem connected and not playing any track. I used to be bothered by this. But after months of trying QP2R with different iems, once music is playing hiss does not seem to be a problem anymore or at list it's masked by the music. For some reason, the longer I listen, the less I notice any hiss even on music with silent passage. At this point I think my NT6 sounds the best with QP2R than any other DAPs I have including LPG, AK240SS, DX200 and Hugo. Everything is crystal clear, full bodied and non-fatiguing which most people find too bright on most DAPs. It just like have the clarity and resolution of KSE1500 but with the thump and fullness of an EQed iSine20.
Of course, I still like Questyle to solve or at least reduce the hiss without sacrificing quality. I thought maybe reducing the gain could do it for sensitive iems.
esauseesaw
Member of the Trade: SCV Distribution
One of the big bonuses of the current mode circuit it is ability to drive difficult headphone loads with ease, it stands to reason that at the other end of the spectrum, with very sensitive IEMs, there might be hiss. Any amp is unlikely to do both really well, without technology like the ifimatch to help out. You can't on the one hand offer bags of power, seemingly more so than even the specs suggest in the case of Questyle, and at same time not potentially over drive a very sensitive IEM. I'm not sure how they can get round that. Including gain settings is a start but clearly there's a limit to how effective that can be, otherwise they could easily implement a specific IEM gain setting.
I'm not a big IEM user so, others might have a better view on this. However, in the absence of the ifimatch, would it be better overall to stick with single ended if you have a particularly sensitive IEM? You don't need the power benefits of balanced and perhaps the subtle improvements otherwise are out weighed by the added hiss...?
headwhacker
- Sep 4, 2013
single ended still hiss on most iems. So it's actually not a better option. While balanced output has twice the output power, it is still very limited. While Mr Speakers recommend QP2R with Aeon closed but I find it has barely enough Juice. On some high DR tracks, QP2R distorts on Aeon due to lack of power. LPG and DX200 can handled big cans better. That makes QP2R limited to matching narrower range of headphones than other DAPs.
esauseesaw
OK, so it's not the 'most' powerful amp out there but also it's about the sound, as you already said. I haven't tried the QP2R/Aeon at length but I will try again when I next get the chance. I do have the new Fostex T60RP here, which has identical sensitivity (92dB/mw) but slight higher impedance at 50ohm. They aren't particularly easy to drive. For my preferred listening levels at least, the QP2R has no problem giving enough power. Sure it's in the upper gain capabilities but I don't hear any distortion at the level I'm comfortable with.single ended still hiss on most iems. So it's actually not a better option. While balanced output has twice the output power, it is still very limited. While Mr Speakers recommend QP2R with Aeon closed but I find it has barely enough Juice. On some high DR tracks, QP2R distorts on Aeon due to lack of power. LPG and DX200 can handled big cans better. That makes QP2R limited to matching narrower range of headphones than other DAPs.
Presently, I'm so freaked out to not drop the damn thing.
Slippery, ain't it!Presently, I'm so freaked out to not drop the damn thing.
Like a bar of soapSlippery, ain't it!
ExpiredLabel
- Nov 1, 2012
Like a bar of soap
B..But the sound is SO clean.......sorry just had to...
I only have logged maybe 1 hour but clean was my first thought.B..But the sound is SO clean.......sorry just had to...
ExpiredLabel
- Nov 1, 2012
I'll be curious about your thoughts later on, until then enjoy!
esauseesaw
A few times, I've had one on my desk and it literally slid off on it's own!? It's like they hover. Case recommended.Like a bar of soap
