Questyle QP2R
post-13676311
Post #211 of 1,115
lafeuill
Paris, France
Paris, France
Age
45
Did both of you try it balanced ?
post-13676347
Post #212 of 1,115
coolcat
Yes I did try only balancedo.
post-13676766
Post #214 of 1,115
lafeuill
Paris, France
Paris, France
Age
45
Lucky you.
I'll have to wait until mid october to have a listen at an audio show in Paris, if Questyle is represented there.
Enjoy.
Reactions: Bart147
post-13680938
Post #215 of 1,115
MP800
Netherlands
Netherlands
As i have been following this and order threads about the QP2R and QP1R I thought to share my findings. I was able to demo both yesterday for a couple of hours. I also compared them to my Chord Mojo. They where listened to with and without cma800r amp.
QP1R-> More low end, dynamics and intimate but smaller sound stage. Louder than QP2R.
QP2R-> More mid based. More referenced. Reverbs are bigger and longer.
Mojo-> Can go louder, but lacks definition.
To me the QP1R seems to be more fun to listen to and the QP2R more referenced. With the HD800 the QP1R is really fun to listen to. Not harsh at all! Though is does lack the big soundstage that the QP2R brings.
With the V-Moda M100 the QP2R sounds a good suit. As the M100 already has that fun factor. The QP2R makes it a tight, clear and great headphone to listen to.
I ended up ordering the QP2R! :)
Reactions: lafeuill
post-13681328
Post #216 of 1,115
twister6
twister6 Reviews
Website
twister6.com
I think for many people, neutral-reference sound of the source (such as your description of QP2R, I don't have either one so just quoting you) will be the way to go because it makes for a better pair up with different headphones/earphones where you hear the actual sound sig of headphones without additioinal coloring by a source.
Reactions: MP800
post-13684317
Post #217 of 1,115
BunnyNamedCraig
Formerly known as MTMECraig/bunnynamedfrank
I to agree with this as well... the times that I change that opinion is when the amp has a different flavor that I like in general (Cavalli amps). curious to get our demo QP2R to finally hear it for my self.
post-13698449
Post #218 of 1,115
headwhacker
I have been playing with QP2R's EQ using my iSine20. Initially, I was getting quite a good responsive EQ every time I made a change. However, all of a sudden changes to the EQ stopped responding. As if the EQ is totally gone or not working. Turning EQ off changing between EQ1 and EQ2 or drastically making a change in one or multiple bands doesn't affect the sound anymore.
I reset my device twice but it appears EQ no longer works. Worst is I think the sound is stuck to the last EQ preset that work and the sound is now totally whack using another headphone.
Has anyone encountered this before? Either on QP2R or QP1R?
post-13698639
Post #219 of 1,115
MP800
Netherlands
Netherlands
I read a post earlier in this thread from @Sound Eq about some problems with eq on certain file types wit the Qp1r. Have you tried different file types?
Even if this is the case it sounds to me like it's a faulty unit.
post-13698694
Post #220 of 1,115
headwhacker
All my files are flac. Besides, EQ worked for at least 2 hrs when I played with it
post-13698892
Post #221 of 1,115
headwhacker
I found what the problem is. EQ does not take effect on 24-bit files.
post-13698898
Post #222 of 1,115
MP800
Netherlands
Netherlands
That's annoying. :frowning2: I receive mine in about two weeks. Will let you know if I have the same issue. I hope this is fixable with a firmware update.
post-13698986
Post #223 of 1,115
headwhacker
At least, I know there is nothing wrong with my device. It appears to be a behavior that exist in QP1R also. Not a biggie to me as I have a separate SD card with only 16/44.1 Flac files. I have been playing with EQ with my DAPs to find out which one works best with my iSine20. So far it's a toss between LPG and QP2R. And I think with QP2R the iSine20 sounds fine without EQ compared to other DAPs I used including Hugo.
post-13699789
Post #224 of 1,115
Satir
Formerly known as Primum Audire
Southeast US
Southeast US
n/a
post-13716964
Post #225 of 1,115
headwhacker
V1.01 FW is now available. Notable changes is the support for gapless playback. Does anyone knows what the "Flip" function does?
