hydesg
- Dec 9, 2013
how is it? really cant wait for mine to get to me!
Some testing
Some testing
Please allow me an other question on DAC choosing for matching with single CMA800R & HD800 (stock cable). Leaving Auralic Vega & Questyle CAS192 out (too expensive for me at the moment) Now I'm choosing between DA8 & Firestone Tobby & Schiit Gungnir. They will be pluged directly into usb of a laptop and as I already noted I'm listening mainly to classical music, mostly elder (60-80) recordings not always of audiophile quality (most recording done prior to 1960 sound on my current system so bad that I skip them at all).
In the Tobby review you stated that you liked it a lot for classical music. But later on you have written that it's a bit on the bright/analytical side and not the best choise for not top quality recordings. Won't it sound bright/unforgiving for not top quality recordings on my system with CMA800R & HD800? Would DA8 be a better choise in this scenario?
In the DA8 review you also mentioned that DA8 sounded noticable better with Audiophilleo or Auraliti PK90 (that I don't have) than straight of the usb on a macbook, at the same time Tobby sounded best over usb even straight from the macbook.
The Tobby will cost me just 50-60% of what I would have to pay for DA8, so DA8 has to be definatly superior for my system to make up the extra expense.
It's sad but I have no other choise than buying them without auditioning first - that's why i'm asking so many questions.
It sound great with ortos and with the HD650, a big improvement compared with single ended.
With the HD800 the improvement are lower.
In that case I would definitely lean towards the DA8. Tobby is brilliant with good recordings, but not very forgiving with poor material. DA8 is a lot more even handing, sounding good with most anything you play.
At half price, Tobby is attractive, but I'm still not sure it's ideal due to your choice of music.
Makes sense - a single CMA800R is already brilliant with HD800 and has plenty of juice, so the extra power isn't needed so much. With planars, the increase is probably more welcome.
Has anyone compared the CMA800R to the ECP Audio L-2 with the HD800?
Not directly. I've heard the L2, love it, and if any amp out there can compete with CMA800R/HD800, the ECP might be it. But that's as far as I can say without direct comparisons.
From what i know, the L-2 is THE best of the best for HD800 ( check the review of Tyll for L-2/HD800 combo @Innerfidelity when comparing with the Abyss 1266). So, now, it seems the CMA800R is of the same league of the ECP...wow...i'm very impressed of this amp....
Your CMA 800R has tubes
