Satcher - HiI'm loving the CMA600i, but I have a couple of issues I would like to be addressed by other owners: when music playback is off for about roughly 15-17 seconds, I'll hear a subtle pop and hear it pop twice quickly before I initiate a track. Is this the same thing as the popping issue people referenced a few pages before? Should I be worried or is this considered normal? Haven't been an audiophile too long. The serial number for my unit is at the XXXX420-430 mark (can't remember exactly), which is before the XXXX500 mark where units were described in this thread as having the issue resolved.
Also, using the ifi iEMatch and my IE800 connected to the CMA600i, when I turn the volume knob more than halfway, at around the 3 o'clock spot, the music skips/ cuts out. Is this clipping? The iFi iEMatch makes me turn the volume knob higher to achieve the same listening volumes I like if I weren't using it. This is listening to music via the USB connection. Did I damage my unit? Does anyone else experience this when they use the iFi iEMatch?
Sorry about the barrage of questions, kind of getting nervous if my unit is faulty or not. It was purchased off of Amazon as a returned unit from an authorized dealer who stated it was free of faults in the listing, but I'm having doubts.
EDIT: Wanted to state that the popping issue is also present with my HD800 via the balanced 4 pin XLR output.
Your serial number is in the potential trouble zone but before knowing that is your issue we need to understand more about your system. Specifically :
1. What are you playing music from when you listen to your HD800? (ie mac, pc, music server, dap)
2. Are you using any DSD files? ( change to dsd can sometimes trigger a noise)
3. Do you have the same issue initiating a track if you are using Tidal, Spotify or some external streaming source ?
4. What power filtering or other measures are you using ?
I had the popping issues but they were worse than you describe so a bit more sleuthing is required with your set up to isolate any likely issues.
Re your ifi ematch - this product normally reduces the amplifier output heaps - up to 24 dB I have read, by using resistors etc. If the end result is your volume dial is at 3 pm that is weird as most of us are listening below 12 noon even with difficult to drive headphones - I suspect using it this way is not ideal and 3 pm is not a sensible outcome - what happens if you use the ie800 without the ematch (just using a simple plug adapter)?
Vincent
