1Time
- Jun 1, 2005
1. Using the same headphones, is an amp with a higher gain setting more likely to cause audible floor noise than the same amp with a lower gain setting?
2. And using the same headphones, would an amp with higher gain setting be more likely to produce more volume than the same amp with a lower gain setting?
Thanks
Thanks
