Questions on using headphones for computer dvd watching!!!
Jun 25, 2004 at 12:57 AM Post #2 of 2
Originally Posted by fatmaneatschild
1> Is it better to select dolby 5.1 or dobly surround 2.0 in the dvd audio options and why?
2> I currently use windvd 4. What do I have to do or get to have DTS audio?
Select the 5.1 DD mix from the DVD menu (actually this is generally the default), but configure WinDVD to output 2 channel. Also make sure to check "Send LFE to speakers/headphones." You should also use the headphones option and select Dolby Headphone. There are three different soundstage options for Dolby Headphone try them and see which you like best.
