Questions about Stax headphones use and fix
post-14492827
Thread Starter
Post #1 of 5
legopart
I having some questions about Stax headphones (again):
1- how can I measure the bias voltage if it correct?
2- how can I test if the headphones are safety to use without any electrification dangerous (if I buy them used
3- What another sponge can you recommend to replace the old used one ?
4- can I connect the SR-40 to SRD-7/SB transformer ?
5-What the best way to connect the SRD-7/SB transformer to PC ?
thanks!
post-14501771
Post #2 of 5
bwck2000
1: Checking the voltage directly from the headphone socket is inaccurate, you need to open up the amp and find a specific test point.
2: All of them is safe to use
3: Only the one made by stax fits so buying a third party earpad wont work
4:yes
5:through a speaker amp
Reactions: legopart
post-14502059
Post #3 of 5
legopart
1- I want directly.
where connect the ground pin ?
3- I can glue another one, as I saw some one mode.
2,3,4,5 = Thanks
post-14505439
Post #5 of 5
legopart
I need replacemant for the wool in my Stax Lambda.
where can I find, Or what can I use for it?
